View Poll Results: witch one is safer ?
Voters: 29. You may not vote on this poll
Boost vs Nitrous: Pros and Cons
Still going to give n2o a try, boost is great like I said before, but here in AZ, I think if you have a turbo its more "fast and furious" than anything.....cause of the dam kids that just want instant fast and take no time to learn and respect it. Thats also why i see a lot of crappy on the "edge of blowing up" cars down here. And also I thought that the age of people taking off there hoods was over....I was wrong....sorry for the rant, just tired of disrespectful people down here not caring and making us die hards look bad!
Originally Posted by Syldrin
the front mount spray bars dont actually add power at all. ive seen 2 cars dynod with them 1 specifically was a test and they added 0 whp. they are great for cooling off your fmic between pulls. other then thalt kinda useless.
If you remember from physics, delta T, or difference in temperature. An intercooler is more efficient when there is a larger delta T when regarding the air temperature versus the intercooler temperature. When the intercooler is colder, it is able to absorb more heat. It absorbs the heat fairly quickly, but cools slower afterwards by letting air flow over the fins of the IC.
When you use a spray bar or internal chilling like my S-Max intercooler, you aren't cooling the air more, but you are allowing the intercooler to absorb more heat increasing the delta T.
Confused yet?
Intercooler spray bars DO work. If you are using a Nitrous setup to spray on the intercooler. Same thing happens when you see people at the track and their crew runs up to the car and blast it with a bottle of N20 right before they make a pass. It gains power for sure doing that. I've seen it gain on a dyno as well.
Yea, I am excited to get some dyno time once I get the CO2 hooked up on my S-Max intercooler. Should be interesting to see how much it helps with the larger temperature difference so it can pull more heat from the compressed air.
I would think nitrous is more F&F than a turbo. Especially with the argument of them just wanting instant fast
Now it just goes back to if you learn about what you want to do to your car first, then you can have fun, and safely.
But in the end the new fast and furious was good....especially in the seats that move with the movie!
We don't need to re-enforce the engine to get 350whp and be reliable with. Not all motors, tuners, cars are created equal.
crimson_sinn
09-25-2015 10:41 PM
