Boost Works Turbo tC Build TRACK VIDEO
#342
#349
im knida thinking that the revs flying up has more to do with something in the drivetrain failing than not having any traction. i run the same slicks @ 9 psi and they hook just fine. also, art was running high 9's with high 140 mph traps with the same slicks. this is why im leaning more towards a clutch/drivetrain problem, which would also explain the strange new noises coming from the trans. also, how long are you doing your burnouts for?
#350
The slicks look old & nasty to say the least - i think a new set will get me some better traction
Decent 2nd gear burnouts .. nothing crazy.
#351
The drivetrain wasnt failing it was just noisy .. imagine if both of your brake dust shields were rubbing on the rotor - thats what it sounds like. It only makes the noise after i put power through it.. After it cools down and I cruise it doesnt make the noise. It drove like normal - was just noisy. I dont think it would be trapping 124 back to back with a busted drivetrain.
like i said im not there so i cant really be sure whats going on. im just guessing based on my experiences. can you take some pics of those slicks?
#352
I will once I get the right one off (thx ichiba wheel studs)
I left my slicks in the garage over the winter. I am thinking this had a negative effect on the rubber.
You have an oem diff/oem suspension right? Are you spinning in 1st or 2nd?
You have the toyo proxes?
#353
How was your traction for the above mentioned runs.
#354
I appreciate your input for sure.
I made 5 or 6 passes. The transmission started getting more noisy after the 4th pass. My traction and speeds were pretty consistent throughout the day. Its odd that i have absolutely no traction in 3rd with such a big tire.
You have a similar setup so information from you is very helpful
#357
#358
When my CC clutch was slipping, i was seeing it in lower gears.. I always presumed once the car was already moving at a certain speed, it was less stress on the clutch. Again not sure.. but thats what i had seen. When slicks are spinning, you can hear and feel it for sure..
Maybe you posted it already but what size of slick are you on?
#359
25x9x15
its odd that the clutch would grab for the burnout - grab for the launch - spin 1st, 2nd, 3rd and grab for 4th. pedal feel did not change. no clutch smell.
I believe the clutch to be fine.
1-3 felt like street tires
Im going to get another transmission and new slicks and go back
