Boost Works Turbo tC Build TRACK VIDEO
#444
A couple pictures.
I wanted to remove all the weight from under the dashboard and I needed access to the throttle pedal so I can swap it out. I will probably put the top part of the dash back on with the cluster and fabricate a gauge panel.
The second picture is the new BBK Mustang 75mm throttle body compared to OEM.
The third picture is how the engine bay looked at the end of last season.
The fourth is mostly how the car sat last year.
#453
Was able to get some work done on the car today. Mostly just mocking stuff up but here are some pictures
I made some progress on the roof but I forget to snap pics ... anyways...
New skinnies (thanks art)
Throttle pedal assembly & throttle cable from a 1G xB I will be using for the conversion. I got it mounted - I will get more pics next time.
New intake manifold & throttle body setup
and I was able to get the battery mounted up
I pulled the ABS module and I have to order a prop valve.
AEM is coming in tomorrow and I will be placing an order for some of the final parts I will be needing.
Stay tuned for a lot of progress over the next few weeks.
#457
A little update
Roof is completed - Going to spray it flat black before final install.
AEM is in along with all my sensors. I have completely taken apart the OEM harness so I can integrate the new connectors for the MAP, ECT, IAT, TPS, Boost Solenoid, Wideband, Oil pressure sensor, Fuel pressure sensor into the harness.
I am about halfway done with this - waiting for some connectors to come in.
I did this so I could also remove the connectors/wires I am no longer using.
SSBC adjustable proportioning valve is in - ABS is out.
Gutted an OEM power steering pump to add an idler pulley to remove power steering.
I ordered steel braided AN hose to do the vacuum lines for the wastegate.
A ton of work left but im getting there.
