Boost Works Turbo tC Build TRACK VIDEO
#521
I know I have about 10 of them sitting next to me. If you are only running 1 my statement before will hold true. You are going to be at the max of that fuel pump.
Its just math there is no guess work. It isnt a matter of fuel pressure drop its a matter of fuel flow.
I plan to hit the track within a month. Waiting for parts to come in.
#522
Got all of the parts for the shortblock in. Ordered a head gasket today and bought a catch pan. Just have to make the scatter shield so I can enter the 10.50 class.
Planning to assemble the engine this weekend.
Hopefully getting the HX40 in there shortly after.
#523
Good stuff!!!!
#528
How much psi are you running? And are the additional 35hp at the same boost level as before? Also what were the final numbers? Cant wait to see you hit the 10s man good luck. Also try to get some vids of your pass if you can
#531
It made 493 on our Mainline dyno which is an estimated 545 dynojet.
ID1000s are at 86% duty with a 93psi base pressure.
Still on pump E85
Still on stock cylinder head revving to 6700rpm.
There should be plenty of media coverage for fall nationals. Keep an eye out on Nyce1s facebook page.
#537
Went to Island Dragway yesterday. Probably the worst track in the northeast.
Only got 1 pass in before the car started pushing coolant.
Ran an 11.29 @ 133mph. Spinning all the way through third. I hook second and third at other tracks no problem. My 1/8th yesterday was 7.5 and I usually pull 7.0s so the 10 second pass was there at a better track.
Going to take the head off and see what the damage is. Hopefully nothing happened to the block.
#538
