Boosted TC cutting out after i went 130mph wtf
That or put a switch on the vss wire to the ECU ;) lol - this basically does the same thing as the EMU. Leave it on (vss connected to ECU) when youre just cruising and want your cruise control to work, than flip it off if youre planning on exceeding 130mph But to be honest, how much past 130 can you go with stock rev limit and stock E350 trans? With E351 and raised rev limit however its considerable. I have a 7400rpm rev limit and E351 and I can hit about 145 in 4th
Well then you are back to needing to get rid of the F/IC, cause it won't raise your rev limit. And do you have a built motor, cause 7500rpms is not happening on a stock one.
I understand that the FIC won't raise my rev limit. Of course I have a built motor (picking up from the machine shop June 1st!). I wouldn't dare try and raise the rev limit that high on a stock motor....that's just asking for trouble!
Well the car ran great for two days and went to start it today and was hard to start and it finally started and isles roughly around 300-400rpm and then I went down the street and the car died on me and wouldn't start then the battery drained. Got a jump and drove car a few blocks home and then died on me. Bought a new battery and will start one time and idle rough and will die and then won't start again. So ____ed off.
crimson_sinn
09-25-2015 09:41 PM
kslim619
09-18-2015 06:54 PM
Subaru86
Scion FR-S ICE & Interior
09-10-2015 08:11 AM
