bosche 110?
the bosch 110 is the bpv on the supercharger setup. You can get it from a few sites around can't think of 1 off hand I'm sure someone will chime in. Its very easy to install that is if you know how to work a screwdriver..They go for about 60 bucks or so.
Hello,
The 110 Bpv is a great upgrade, but SL has hype it up. I have Auto S/C and I think its ok...but here is where you can get it..
http://www.hoppenmotorsport.com/
I wouldn't go with the bosch 110 BPV...Hyperboost makes a great part, I like that it is all metal and uses a piston. Does cost at bit more...
http://cgi.ebay.com/ebaymotors/Hyper...spagenameZWD1V
TINCAN, can you back up your claims about the bosch 110BPV. I made 543rwhp with a bosch 110 with 0 leaks. for the price, you can't beat the 110. who cares if it's plastic, it's got a beefy internals.
all this he said/she said bull____ on the internet.
Or u could go with the Forge 007 BPV which is way better than both of the Boschs, but is twice as mush as 110.
The Forge 007 BPV is a real aluminum BPV, not plastic and it has a real piston in side. Not a plastic diaphram. You get three springs you can inter-change for how stiff you want the piston.
Bosch 102 = Free with kit
Bosch 110 = $55 online
Forge 007 = $105 online
You pick
Forge 007 is great though. Alot better than the 110, but the 110 is way better than the 102.
I'm just putting info out there...I run a Hyperboost in my car and it works great...to each his own. I'm not knocking the 110, I'm just saying I wouldn't put it on my car is all.
You pick
the audi's use the same bpv as us, so yes it will work. No it isn't bad if you went with the 110, I have had all 3 the 102,110, 007, I personally can't really tell much difference between the 110 and the 007 except it looks nicer and its metal. Get what you want, if you don't plan on going with allot of boost get the 110, you'll be fine.
www.forgemotorsport.com/
You want the FMCL007P - http://www.forgemotorsport.com/conte...oduct=FMCL007P
motozen
28
11-21-2005 09:06 PM
