BOV or BPV? for TRD S/C
Old 10-05-2007, 04:45 PM
Gerard_gmaiz's Avatar
Default BOV or BPV? for TRD S/C
I am going to purchase the HKS sequential BOV.
my question is
Does the BPV gets eliminated or not?
What kind of noise doess it makes? swushh?
Gerard_gmaiz is offline
Old 10-05-2007, 05:08 PM
equinox2355's Avatar
BOV typically arent good for a S/C and the BPV on mine I hear it click, but no woosh sound like a BOV since the air is just put back into the intake system.
equinox2355 is offline
Old 10-05-2007, 05:19 PM
nauticac's Avatar
i be makin muh ride go swushhhh for madd tite horsep0wer y0.
In all seriousness, a BOV typically isn't good for a s/c as stated above.
nauticac is offline
Old 10-05-2007, 06:57 PM
I talked to one member who has the hks bov and he said that the bov works good.
but
does the bpv gets eliminated?
please someone who has /had the hks bov
Old 10-05-2007, 07:02 PM
monkeysauce's Avatar
A BOV will replace the BPV. It's one or the other.
As stated before, a BOV on the SC will make your A/F go wacky and lean, which is not worth it for the sound.
monkeysauce is offline
Old 10-05-2007, 07:06 PM
thanks
so I will go with the bosh 110 bpv
Old 10-05-2007, 07:39 PM
zero__zero's Avatar
Or if you're looking for the sound, you can go for the Forge Hybrid SPLT-R...recircs most of the air, but also has an atmospheric portion that gives you a little "whoosh" sound...it's nothing major, but it's definitely more audible than a BPV.
If you're running the TRD reflash, your car needs that air recirced into the intake so that the ECU can meter out the proper A/F mix...
zero__zero is offline
Old 10-05-2007, 10:34 PM
Sleep3r's Avatar
do a litte more research.
for upgraded bpv you can get a bosch 110 or forge 007
the bosch 110 is cheaper but someone told me that pretty much after one year you have to replace it.
the forge 007 is more expensive but it also comes with a tuning kit, meaning different colored springs that hold different boosts.
i am personally using the forge 007 w/ blue spring and 2 shims. others have used the red spring.
at WOT it does sound nice
Sleep3r is offline
Old 10-05-2007, 11:53 PM
BuddhasTC's Avatar
ok first of all, the BOV is not bad for the supercharger and it alone does not make your car run lean. It's usually when coupled with the CAI where it makes your car run lean. And also the A/F ratios do not go "whacky". My A/F ratios stay pretty good according to my wideband gauge. But as they said, it does replace what would be a BPV. I have the HKS SSQV BOV and it sounds AND works great! I just recommend getting a piggyback (or standalone if you got the cash) instead of the reflash with a good dyno tune and you will be in great shape
BuddhasTC is offline
Old 10-06-2007, 12:59 PM
I think your experience is the only one that says BOVs are without problems
Old 10-06-2007, 10:06 PM
mahalzkita28's Avatar
i can back him up on this one. im also running the HKS ssqv bov VTA. no recirc here. great valve.
there are a few others that work...
gfb hybrid = POS, leaks major boost, real loud though.
greddy rs = good at holding boost, some say it leaks but i havent experienced it, makes a woosh noise, not as loud as GFB but way more audible then the forge splitters ive heard on youtube
mahalzkita28 is offline
Old 10-08-2007, 02:01 AM
06SuperWhite_SoCal_tC's Avatar
I believe BrownDogg is running a HKS Super Sequential on his TRD tC. I don't know how it sounds though... I do know its pretty easy to run a BOV on a s/c tC though.
06SuperWhite_SoCal_tC is offline
Old 10-08-2007, 02:04 AM
anyways "Wooosh Sound" = teh Gayness. Gets annoying very quickly.
Old 10-08-2007, 06:38 AM
you dont need to get into boost if you dont want to hear it
Old 10-09-2007, 08:45 PM
I don,t care if it goes lean because with the apexi neo i can tune it well
but do you loose whp for that boost that escapes?
Old 10-09-2007, 09:39 PM
jwaggz82's Avatar
bpv or 50/50 split - search it ... we have talked about it more then once and have always concluded on NOT using only a bov.
jwaggz82 is offline
Old 10-10-2007, 07:22 AM
BuddhasTC's Avatar
He was, i'm running his setup now
Old 10-10-2007, 07:44 AM
ah, any sound clips... from either of you?
Old 10-10-2007, 07:50 AM
BOV don't serve a purpose other than to make teeny bopper girls giggle when you drive by... lol
BOV = teh lose
Old 10-11-2007, 01:36 PM
BuddhasTC's Avatar
https://www.scionlife.com/forums/vie...910373#2910373
my most recent ones in this thread
Quick Reply: BOV or BPV? for TRD S/C
