broken exhaust manifold stud
well the bolt was still on there but looked weird so when i went to touch it the bolt just fell off so i look at it and the bolt was like a dark purple ish color and a friend said that it got to hot or something like that but ill put up some pictures
How far down did it break off, if you have at least 1/4" left you can use my patented trick Take a nut thats slightly bigger than the shat, slip it over it, mig weld the ____ out of the inside of the nut to the shaft, remove with socket, ive gotten many a borken bolt out this way, but if it broke of flush with the head than only option is to machine it out.
Originally Posted by Ace83
how did you broke it? did you have any accident or something? post some pics
Go to Toyota and get new studs. Take some vice grips and latch on to them and unscrew them from the block. I had one break about 1/4 inch from the block and that's what I did.
darkshadowofxdeath
11-22-2014 06:46 AM
