Built Block need a balance??? Carrillo Rods Wiseco Pistons
Old 06-18-2009, 02:37 AM
johnhawkins's Avatar
Default Built Block need a balance??? Carrillo Rods Wiseco Pistons
I currently have Napa auto parts building my block with Carrillo rods and Wiseco pistons....I will also be deleting the balance shafts. Do I need to get the block balanced....Napa had mentioned to get it balanced. Any insight would be appreiated. Thanks!
johnhawkins is offline
Old 06-18-2009, 03:01 AM
yamaha16bw's Avatar
Never a bad idea.
yamaha16bw is offline
Old 06-18-2009, 03:18 AM
gingles's Avatar
get the crank balanced.....and have them match the rods and pistons together weight wise so they are all close to the same weight......all i did was get my crank and pistons balanced and assembled it myself.
gingles is offline
Old 06-18-2009, 03:27 AM
m6ar2cel6oTC's Avatar
wait! napa builds motors? damn i never knew that. if you dont mind me asking how much are they charging you?
m6ar2cel6oTC is offline
Old 06-18-2009, 04:30 AM
RusWolf's Avatar
hey i got a question then as well..
I'm getting fully built block from ERL do you guys think its already balanced ?
RusWolf is offline
Old 06-18-2009, 07:39 AM
Music City Scions
BlackKnight's Avatar
Yes it needs to be balanced even if the factory says they balanced everything still have it at a minimum rechecked.
The stoker kit I bought says it was balance but I'm have the shop rebalance it even closer so I can have a longer lasting engine and be able to safely rev a little higher.
BlackKnight is offline
Old 06-18-2009, 10:52 AM
crush02342002's Avatar
i think i read that they were...ill check real quick
crush02342002 is offline
Old 06-18-2009, 11:50 AM
Music City Scions
Almost all engine builders i.e. ERL performance and such will balance it to certain point. This is why I am paying the shop to take it further for safe operation at higher rpms.
Old 06-18-2009, 01:52 PM
10sec05's Avatar
balance it and you can rev higher.. thats about it
unless you are doing a very serious NA build with titanium rods or something
you are not going to notice vibrations with K1/Carillo rods and forged pistons.. even when removing the balance shafts
10sec05 is offline
Old 06-18-2009, 04:27 PM
RSracer's Avatar
ALWAYS balanance your entire rotating assembly. To do that properly they need..
-pistons & rings
-rods
-crank
-crank pully / balancer
-flywheel
-all bearings
There isn't any reason not to. You won't see professionally built engines go out the door unbalance from the companies that sell shortblocks for the tC.
RSracer is offline
Old 06-18-2009, 04:29 PM
10sec05's Avatar
-pistons & rings
-rods
-crank
-flywheel
-all bearings
$ + downtime
10sec05 is offline
Old 06-18-2009, 04:36 PM
RSracer's Avatar
-pistons & rings
-rods
-crank
-flywheel
-all bearings
$ + downtime
Thats more on the lines of a lazy excuse.
You're building a performance engine and you want to skimp out on $175?!? Almost any engine shop could do that with a fast turn around. If you can't afford to have it balanced and done the right way you might want to reconsider your project. I'd be pretty worried to see the rest of your build.
RSracer is offline
Old 06-18-2009, 04:51 PM
Music City Scions
I'm sorry I agree with RSracer get it balanced. That is just like reusing head bolts or studs you shouldn't do it point blank buy new ones.
Old 06-18-2009, 04:53 PM
1UP Crew
Crippie's Avatar
dont mean to threadjack, but for all you guys with built motors already, what piston/rods did you use for your set up and why? Im in the process of researching this and would like to know differences. From what ive seen so far, Piston choices are :Wiseco; JE; CP... any others?
Crippie is offline
Old 06-18-2009, 06:41 PM
nodsetse's Avatar
$ + downtime
That's often the result for those that don't get it balanced.
It's kinda like that old advertisement, "you can pay me now...or you can pay me later"
nodsetse is offline
Old 06-18-2009, 06:47 PM
jwaggz82's Avatar
there are two sets of people who get their engines built. Ones that are shooting for a safe 330-430whp rating and ones who are looking for a 500whp+ mark. So, you will be getting a range of answers. Which are you thinking so that someone can help you? I would assume the first.
jwaggz82 is offline
Old 06-18-2009, 10:17 PM
1UP Crew
Crippie's Avatar
you are correct sir.. looking for a safe 400-450whp mark
Crippie is offline
Old 06-19-2009, 01:05 AM
$575 w/Tax for resurface and bored out and assemble the block
$300 w/Tax for balance
I plan on running 20psi with .63Turbine .50Compressor
Old 06-19-2009, 03:58 PM
RSracer's Avatar
I've used Mahle in a tC motor but in my engine I've got Wiseco. My tuner also recommends Wiseco and won't build an engine using any other.
RSracer is offline
Old 06-20-2009, 01:39 AM
aen
aen's Avatar
you never ever ever leave a block unbalanced. that's a recipe for disaster, also, nomatter how much you trust the shop that is doing your work take the thing apart and measure clearences youself, make sure theres no oil or grease on hte wrong side of hte bearings blah blah
double check your double check.
aen is offline
Quick Reply: Built Block need a balance??? Carrillo Rods Wiseco Pistons
