Built Engine Trouble? Need Help
Old 07-15-2008 | 07:46 PM
guttedtc0's Avatar
Default Built Engine Trouble? Need Help
This weekend I put in K1 Rods, CP Pistons, ACL Rod Bearings, Cometic Head Gasket, ARP Head Studs.
I have 112 miles on the car right now.. have not gone over 2600RPM's
I have a few concerns right now I am looking for help with
1) When i turn the car on it jumps to 2000RPM's and goes back down
2) Vacuum is a little low.. around 15 at idle.. normal while driving
3) MAIN CONCERN - At idle and then again at exactly 2500RPM's the car shakes VERY badly.. the whole car.. sounds/feels like I have steel motor mounts at those points.
We opted to keep the balance shafts and I am almost positive the timing on the chain in dead on.
My ideas:
1. crank needs to be balanced
2. balance shaft chain timing is off
3. remove balance shafts
4. no idea
5. no idea
need some help
Old 07-15-2008 | 07:58 PM
Scott8's Avatar
when I start my car first thing in the am it revs high around 2K for about 5 seconds and drops down.
the rest I have no idea
Old 07-15-2008 | 08:01 PM
B_Real45's Avatar
Gutted,
I would take off your pan and check your bearings. Make sure there's no damage yet - and disassemble. Double check EVERYTHING. You don't want to damage any of these new costly parts.
Old 07-15-2008 | 08:12 PM
Ace83's Avatar
Ronin Scion
watching
Old 07-15-2008 | 08:21 PM
B_Real45's Avatar
Also - I'm not too familiar with the K1's in our engines - but do these require notching to clearance?
Are you still using the stock crank pulley?
Old 07-15-2008 | 08:22 PM
brett561tc's Avatar
i know for a fact my carrillos did.
Old 07-15-2008 | 08:25 PM
B_Real45's Avatar
Yeah that's why I asked.. I remember Carillos needed that notch. Maybe a quick answer would be to find the width of each K1 and Carillow and compare.
Old 07-15-2008 | 08:39 PM
guttedtc0's Avatar
Still on the stock crank pulley.
ScionGT35R used the K1 rods and said it did not have to be notched
Old 07-15-2008 | 08:45 PM
Guru's Avatar
K1 rods are tiny for an aftermarket rod so I doubt clearance is an issue. Any noises when the vibration hits?
Old 07-15-2008 | 09:04 PM
guttedtc0's Avatar
nope just intense vibrations.. the whole car
starts getting noticable at 2450RPM in every gear
at idle the vibrations are more than normal also
sounds like I have aftermarket cams in the car
Old 07-15-2008 | 10:53 PM
t_urbo_C_harged's Avatar
did you have the whole assembly balanced? by assembly I mean piston, rod, and crank assembly???
Old 07-15-2008 | 11:15 PM
java09's Avatar
Originally Posted by Ace83
watching
watching you watch this thread....
muuuaaaahahahahaaaaaaaaaaaa
Old 07-16-2008 | 12:20 AM
guttedtc0's Avatar
nothing balanced
this is what everything seems to be pointing to.. unfortunately
Old 07-16-2008 | 01:50 AM
B_Real45's Avatar
No he did the install in his garage with the engine still in the car.
Old 07-16-2008 | 03:55 AM
guttedtc0's Avatar
when I bring it up to about 2700RPM's and let it sit there for a few seconds it sounds like a knock
rod bearings is my next guess
Old 07-16-2008 | 10:24 AM
malloynx's Avatar
sounds like a first order vibration. what was your final clearance in the rods and mains? does it sound like a rod knock? did your prime the oil system before starting the vehicle?
Old 07-16-2008 | 12:30 PM
ScionGT35R's Avatar
Thats correct!!! No notching it's needed for the K1's
Old 07-16-2008 | 12:49 PM
Guru's Avatar
What is oil pressure at?
Old 07-16-2008 | 09:19 PM
guttedtc0's Avatar
first order vibration?
sounds like a rod knock when I bring it up past about 2800
Old 07-16-2008 | 09:25 PM
guttedtc0's Avatar
Has ANYONE put the K1 Rods and CP Pistons in their cars and either had or not had the rotating assembly balanced? Looking for this info.,
Quick Reply: Built Engine Trouble? Need Help
