Built transmission for boost, what is needed ?
Old 04-21-2010 | 07:13 AM
RusWolf's Avatar
Default Built transmission for boost, what is needed ?
hey guys i'm thinking about building transmission to handle boost safely.
I know some components to be done.
1) Clutch
2) LSD
What else can be done to it so for example if i boost in 4th or 5th gear my tranny won't blow up.
Thanks.
Old 04-21-2010 | 12:21 PM
emrules2001's Avatar
new flywheel will help as well
Old 04-21-2010 | 01:06 PM
Ace83's Avatar
Ronin Scion
cry/ REM treatment
Old 04-21-2010 | 04:36 PM
nolo4820's Avatar
Why not use the stock fly wheel with a turbo? Is it necessary to replace the flywheel? Right now, I have the TRD LSD and the EXEDY STAGE 1 for the transmission. Flywheel was never a thought, should it be?
Old 04-21-2010 | 06:08 PM
Ace83's Avatar
Ronin Scion
not really needed, but it will make you rev faster
Old 04-21-2010 | 06:15 PM
m6ar2cel6oTC's Avatar
Originally Posted by Ace83
cry/ REM treatment
This.
Old 04-21-2010 | 07:26 PM
RusWolf's Avatar
ok so far i have the following:
1) ACT HD street clutch
2) competition 12lbs flywheel
TRD LSD is next.
so pretty much for the gears and to make them stronger the only thing is to have them Cryo/REM treated ? and nothing else can be done ?
How much do that usually run for ?
Old 04-21-2010 | 07:42 PM
trd07tc's Avatar
5th gear?
what are your power goals?
Old 04-21-2010 | 07:45 PM
greenbean24's Avatar
I am in the same boat as you Wolf as far as building something stronger than just an LSD/clutch combo,
I am curious as to how much stronger the cryogenic treatment will make the tranny as well as cost.
I found this link but I'm not sure how close the pricing would be in your local area,
http://www.nwcryo.com/motorsports_price.html
Complete Transmission: $135,
Which seems a little low but then again I've only heard of exotic piston and such being cryo treated...
Old 04-21-2010 | 08:07 PM
RusWolf's Avatar
Originally Posted by trd07tc
5th gear?
ultimately 500whp.
but for the near future whatever i can safely get out of 20 psi and then i'm going to stop and concentrate on suspension and making the power reliable.
Old 04-21-2010 | 10:07 PM
GetIt's Avatar
I'd def scoop up some drive shaft shop guys also......
Old 04-22-2010 | 01:19 AM
trd07tc's Avatar
i dont understand why you want a stronger 5th?
our transmissions at the junkyard are like $100-$200 just run stock ones
Old 04-22-2010 | 03:50 AM
streettimetc's Avatar
there $300-$500 and more then 50k miles here in maryland. aways woundered if andrewtech and ppg gears would come out with gear sets for our trannies. like they have for wrx/sti. but the again for a andrewtech tranny is like $5000.00 but there good for 900+wtq.
Old 04-22-2010 | 04:05 AM
trd07tc's Avatar
i doubt anyone ever makes anything gear wise for our transmissions
blow up a stock one then worry about it
Old 04-22-2010 | 05:40 AM
RusWolf's Avatar
I think its a pain in the butt to switch it out of it blows plus i dont have lifts and i dont want to pay to the shop to do it in case i blow lets say 4th gear or something like that.
Old 06-24-2010 | 02:55 PM
upStyles's Avatar
i just blew up my tranny...anyone know of anyone selling used ones?
Old 06-24-2010 | 03:30 PM
FlintMica2005's Avatar
TCpete is the only person i know with different gearing on his tranny, you can ask him to see what he did.
Old 06-24-2010 | 05:03 PM
rhythmnsmoke's Avatar
Music City Scions
"Blow up" is being loosely used here. Our trannies don't Blow up people. It's the synchros that fail in 4th gear (and in some freak accident way a 5th gear could fail...happen to me). But the trans itself will not blow up. Only solution to the stock internals of the trans is Cryo/REM treatment as said before. However that is not 100% fail safe either.
Other more expensive solution is a Dog Box. But you are looking at $7k last I checked for a dog gear box.
Old 06-24-2010 | 07:23 PM
You say that our trannys don't "blow up", but how do you know that? My carrier bearing and the wrist pin in the diff went out, milling a hole in the case, sending fluid everywhere, starving the other gears for fluid untill it wouldn't even turn over. This all happened in about 20 seconds. I'd say it blew up.
The problem I have with our tranny is that there is no aftermarket support and if you make any appreciable about of power, you can't really put it down without fear of losing 4th.
Old 06-24-2010 | 07:25 PM
Rythm, I wasn't meaning to attack you, I just get frustrated at how flimsy these trannies are compared to the stuff available to other cars
Quick Reply: Built transmission for boost, what is needed ?
