Built transmission for boost, what is needed ?
#42
#44
i dont like putting people on blast but take what cory says with a grain of salt. he likes to tell stories. dunno if he's changed but when i lived in CO he did.
#46
Wow j being j let it go lol everything with my car is well documented. Dynos time slips. The tc tranny is shorter but I can tell u likes to shift faster the xb does have a cast end cap instead of stamped but they do bolt in place the shift linkage has more mass on weights in the xb
Sent from my PC36100 using Tapatalk
#47
Take it easy on the shifts. If you have destroyed three transmissions something isn't right. Are all the bolts that are supposed to hold the trans to the engine being used? Are the bolts that hold the transmissions together are they torqued correctly?
Gears shear when transmission cases flex. You are making more power so yes that's a problem but you are shearing the leading edges of the teeth.
What ever you are doing, you're doing it wrong.
my06tc
06-25-2015 01:18 AM
rancur3p1c
12-19-2014 05:30 PM
06, built, casing, cryo, dog, failure, gears, pin, s2000, scion, springfieldmo, tc, tranmission, trans, transmision, transmission, treating, wrist
