Calling all supercharged Tc's!
Old 10-13-2011 | 04:37 AM
sci0n-tc's Avatar
Default Calling all supercharged Tc's!
Calling all supercharged tc's. I had recently installed a s/c on my car last weekend and was told I can make the BOV/BBV atmospheric "louder". So today I took off the re-circulation hose off and plugged up the bov inlet of the supercharger. Started the car, and immediately it didn't idle correctly and my AFR's were way rich from 10.1 and below. Put everything back to normal and it ran just fine. So can I not use a hks bbv to atmospheric? or am I missing a vacuum issue??
Old 10-13-2011 | 05:32 PM
gompka's Avatar
I had mine setup as atmospheric and it ran fine, only ran rich between shifts, which added a nice gunshot style backfire every now and then.
Old 10-13-2011 | 07:02 PM
SoccerBoy_AP's Avatar
I've never tried fully atmospheric with my hybrid; only fully recirc and partial.
Did everything go ok with the ECU flash from Mountain State Toyota?
Old 10-13-2011 | 10:47 PM
sci0n-tc's Avatar
Not really! I wasted 1 hour there, come to find out they don't have the sim cards needed to flash the ECU. The service tech told me no more were produced after they discontinued the s/c. So I found a member on here selling a flashed ECU cheaper than what the dealer was going to charge. Car pulls good! but like you said even with the 9.5 pulley it only gets to 5 maybe 6 psi, not much but it gives the beast some pep!
Old 01-30-2012 | 09:54 AM
silver_jazzy's Avatar
i just installed a turbosmart dual port bov and been havving idling issues to the point where the engine would stall. i have the spring tightened all the way. any tips?
Old 01-30-2012 | 10:18 AM
DeAnzaJig's Avatar
well make sure you cap off the RECIRC tube (not the tube under boost), and check for vacuum/boost leaks. then report back.
Old 01-30-2012 | 07:28 PM
AZGuy's Avatar
I have the dual port as well, I had to tighten it down pretty far to get it to idle and not have the random die when throttle was removed while running hybrid mode. Once I got this dialed in I didn't like how my AFR was all over the place at partial throttle on the freeway where it would transition to atmo. I ended up putting it into full recirculation mode but will probably mess around with the hybrid mode again some more.
Old 01-30-2012 | 07:51 PM
Syldrin's Avatar
why don't you guys try the synapse BPV? i hear good things about it and you can make it a 50/50 hybrid
Old 01-30-2012 | 08:40 PM
you think a proper tune would fix this? btw are you running any piggyback or any engine management?
Old 01-31-2012 | 03:01 AM
AZGuy's Avatar
Yes I'm running unichip tuned with the 12psi pulley.
Old 01-31-2012 | 03:40 AM
JDMTC5's Avatar
What kind of BPV or BOV would u guys recommend? I just installed my kit 2 weeks ago.
Old 01-31-2012 | 10:20 AM
where do you live? you actually found a shop that tunes unichip? im currently on trd reflash tune and my unichip is sittin in my room just waiting for me to find a tuner. lol.
oh and my 07+ supercharger's pulley bolt seems to be locked with this flower shaped bolt. how do you remove that bolt? planning on just keeping the pulley stock to prolong supercharger life but you never know. i might go 9.5 lbs later on.
Old 01-31-2012 | 02:43 PM
AZGuy's Avatar
I have it tuned in Phoenix, AZ. Do some searching on here on how to remove the bolt, does take some work. If you live in AZ I do have a key to take it off the bolt.
Old 01-31-2012 | 09:40 PM
where did you get the key from? toyota? do you have a link for the thread that talks about removing it?
Old 01-31-2012 | 11:28 PM
AZGuy's Avatar
I made the key which is also in this thread and they also discuss how they removed theirs.
https://www.scionlife.com/forums/sho...ighlight=azguy
Old 02-01-2012 | 09:53 AM
thanks azguy. youre the man.
Old 02-01-2012 | 09:57 AM
and if i get the 9.5 lbs pulley do i have to get a shorter belt? do you know what size?
Old 02-01-2012 | 10:32 AM
btw i have a dayco 5070900 belt on right now. its effective length is 90 inches and it sits pretty tight around the pulleys. how much smaller is the 9.5 lb nst pulley? if its smaller by just a tad bit then maybe the belt i have on will do since its sitting kind tight right now?
Old 02-01-2012 | 01:41 PM
AZGuy's Avatar
You will need a new belt.
Old 02-01-2012 | 09:45 PM
do you know thed length of the belt?
TheRealShark
Scion tC 2G ICE & Interior
08-05-2015 06:08 PM
kanundrum
Regional - Mid South
08-04-2015 05:23 AM
sgetchius143
07-28-2015 10:55 PM
StxArOne
07-13-2015 07:25 PM
Quick Reply: Calling all supercharged Tc's!
