Camry Block with Scion Engine Bay
Ok I used a camry engine with my new motor which I thought wouldnt be a big deal. Turns out the Timing Chain cover has a different mount set up for the top left (passenger side) mount! All other mounts fit perfect. My car is tuned and ready to go but im afraid my motor with fall down, destroying my axles, power steering or even more. I need advice. Has anyone else done this before? Would I need to fabricate something? I need advice not dumb remarks please. Thanks
Originally Posted by gingles
hmmm.....i thought 2az's were all the same
i would say compare the mounts and see if a stock tC mount can be modified or check into getting one fabricated...
Ok well after extensive research this is what I've found. You CAN ditch the timing chain cover! The bolt pattern for both covers are identical. The only difference is the outside of the cover where the motor mount attaches itself to the cover. I also found out that the motor I have is equiped with oil squirters that reduce the changes of burning oil. The cover is expensive so i think im going to have a motor mount braket fabricated. Hope this helps anyone whos ran into the same problem or considering using a camry motor.
geeze... I wish they would not do that.... one of the primary reasons engines are so damn expensive is due to engines that should be otherwise identical not being so, even though they all produce nearly identical power curves.
lol the one with the hole has ben fixed i welded up the hole no leaks its on a non load bearing part i have that and a motor out of a tc that is un touched with 12000 miles on it the one with the hole in it it torn down to a bear block
aight im coming over to steal one...lol...j/k id like to see what you might give one up for? just curious...around here at a junkyard they want atleast 2g's for a 2az out of a tc...____es me off
dont really need the harness but hey extra doesnt hurt either...lol
thanx alot brethren...pm me if ya find something...btw how much is shipping an engine? prolly cheaper for me to pick it up...lmao
darkshadowofxdeath
12-03-2014 06:59 PM
