Can anyone help me find this part!
Old 08-02-2011 | 03:24 AM
Vindiesel075's Avatar
Default Can anyone help me find this part!
I need the bottom rubber piece to an injector (not the insulator that fits into the head)....I have a misfire every 150 miles (during idle or when pulling out) or so that throws at the cel code p0304( misifre cylinder 4 was p0301 before i moved it so the problem follows this particular injector) andd i have a feeling that the bottom rubber piece has a small flaw or cut in it or the injector is not properly flowing consistenly. it only happens on idle and as far as i can tell it is seated properly and has no fuel leaks.....My real problem is I cant get these from the factory and deatch werks injectors do not come with them nor can they get them for me they are pulled off the stock injectors...i tried several junk yards and none of them have any tc's with injectors. If anyone can help me or knows where i can get one please let me know!!
Thanks
Vinnie
Old 08-02-2011 | 03:38 AM
VINC3TC1's Avatar
Are you talking about the O-Rings.
Old 08-02-2011 | 03:43 AM
LED-Maniac's Avatar
best bet is the dealer on that one, take the whole assembly with you too since thatch what you might have to buy if its not available separately.
Old 08-02-2011 | 04:06 AM
Its the bottom cylinder shaped rubber piece. Its not the top oring and i cant get it at the dealer i tired....
Old 08-02-2011 | 02:59 PM
ROCKLANDTOYOTA's Avatar
you talking about the INJECTOR VIBRATION INSULATOR and not the o ring right???
23291-41010
Old 08-02-2011 | 10:11 PM
aryana159's Avatar
this?
http://www.deatschwerks.com/products...or-o-ring-kits
Old 08-03-2011 | 04:51 AM
No not the top o ring and its not the bigger rubber piece on the bottom.....its the bottom cylinder shaped hard piece of rubber
the bottom of the injector check this pic http://www.google.com/imgres?imgurl=...1t:429,r:9,s:0
Old 08-03-2011 | 01:21 PM
PeArLwHiTe07tC's Avatar
i know exactly what ur talkin about. its the little piece that snaps in over the nozzle, than the vibration damper snugs up around it... best bet is to find a set of untouched used oem injectors. u cant get that piece separate from the dealer. i tried doin some research to see if there are any other cars that have the same size injector cap but i came up with nothing. u can use either rav4, 4 cyl camry, or a gen 2 xb injector. u should pm crush, i think he had a thread with those for sale. good luck in the find.
Old 08-04-2011 | 01:28 AM
Thanks man lol finally someone know wat i am talking about lol
Old 08-04-2011 | 01:34 AM
Take a peek in the ppc. I think my buddy mike (trd07tc) has some oem injectors for sale.
Old 03-06-2012 | 09:14 PM
D1G1T4L's Avatar
I was looking for these too. They are called pintle caps and here is where you can buy them for our injectors:
http://injector-rehab.com/shop/Denso...Scion-Cap.html
Old 03-06-2012 | 10:44 PM
aryana159's Avatar
i have set of oem injectors if needed for sale lmk
Old 03-07-2012 | 01:02 AM
YESSSS FINALLY!!! Thank you man! i got rid of that misfire though i dont think it was the problem but i know if i get it out next week and i get one im changing them
luckypixi
01-28-2015 06:29 PM
AxRxP
01-18-2015 06:43 PM
Ramroids55
01-16-2015 03:42 PM
scion1255
01-10-2015 02:56 AM
roo
18
10-08-2003 06:04 AM
