Can i hit 450+/-??
Old 09-07-2010, 02:45 AM
BlckdOutTC's Avatar
piece together your own kit and get cusom fabbing done. if youre gonna build the block and head like that and want to make 450+, don't settle for the greddy components. You will need A LEAST a garret 30/20g. A dude on here i know locally had a fully built block, fic, i think 900cc inj. or something, a gt35r, and the tune to 22psi i think it was. and he was making around 450. So yes get a mani, external wasegate, and a gt35 with your built motor and a solid tune will net you those numbers. but as ace stated, with a 25g it should bolt up, and be capable of the numbers your looking for.
1000cc to keep it safe, bigger IC, bigger turbo!
BlckdOutTC is offline
Old 09-07-2010, 04:05 AM
Guru's Avatar
With the 18 or 20G I will chime in and say no way. GT35R will though. I have a full kit (WAY nicer than the Greddy setup you have) that I'll be removing this month and selling. Getting rid of car so no more use for it but it's a solid kit, NO problems of any kind ever. You'll want to go external gate anyway for your HP goals and setup.
Guru is offline
Old 09-07-2010, 12:27 PM
m6ar2cel6oTC's Avatar
Sent from my iPhone using Tapatalk
m6ar2cel6oTC is offline
Old 09-07-2010, 04:23 PM
Syldrin's Avatar
FP red is a mitsu flanged turbo. they are expensive but evo and sti owners make good power out of the FP series turbos.
Syldrin is offline
Old 09-07-2010, 04:40 PM
Ronin Scion
Ace83's Avatar
yes FP red or green! no need to switch manifold.. but if you do go for an external wg route and change out your mani you will have tons of option with a T3 flange
Ace83 is offline
Old 09-07-2010, 04:50 PM
Syldrin's Avatar
Gunna pay for it but they are great turbo's
Syldrin is offline
Old 09-07-2010, 11:33 PM
1UP Crew
Crippie's Avatar
Originally Posted by Spicy_McHaggiz
Sounds FAR too much like ricer math, there are so many variables. Mod the car then ask what people think you can get.
what do you think im doing?
Thanks for the info guys... as is right now, funds are running low, but hoping to get up and running at least with the 18g for now... gotta save up for the turbo upgrades then... thanks guys
Crippie is offline
Old 09-08-2010, 12:59 AM
bluesciontc's Avatar
Ditch everything Brian Crower, Dont knife edge the crank (no need to it doesnt run in a pool of oil), Pulley is a bad idea get a ATI super damper, Dezod return fuel system, New turbo setup all together (dezod Alpha series!!!).
bluesciontc is offline
Old 09-08-2010, 02:22 PM
NHTC's Avatar
I would stay away from any log-type cast manifolds for that wheel HP goal...Go External gate, larger turbo,QUALITY tubular mani. There are other factors too that will determine how much power you make. How much boost are you looking to run? What octane fuel do you plan to use?
NHTC is offline
Old 11-05-2010, 10:35 PM
1UP Crew
Crippie's Avatar
almost done with the build... when i get a chance... ill post my findings
Crippie is offline
Old 11-05-2010, 10:45 PM
please do. whos building it again?
Old 11-06-2010, 01:43 AM
1UP Crew
Crippie's Avatar
the valves and machine work were done by mesa balancing, the block and engine install myself
Crippie is offline
Old 11-07-2010, 12:22 AM
krazylowgsx's Avatar
you guys really don't think the greddy kit can hit 450whp at a high boost level?? I would put money on it! Crank that baby up to 30psi and let her rip. It will be way out side its efficiency range, but I bet it would hit the numbers hes looking for.
And the Red or Green turbo may "bolt up" to your manifold, but they wont fit in the car. The position of the 18g is just right for it... if you pull it out and throw an FP turbo it there.. its not gonna fit. I actually had the FP3065, and it was a bad ___ turbo! However.... you could pick up a journal bearing presicion turbo simalar to the Garrett GT35r for waaaay less $$$$.
Your on the right track bro... but i would honestly ditch the greddy kit, and piece together your own. That way, you get what you want and not a "kit".
krazylowgsx is offline
Guilles_Tc
Scion tC 2G Aero & Exterior
10-15-2015 03:09 AM
Brownbelter1
09-22-2015 09:31 PM
Mjdavis1994
09-21-2015 04:42 AM
jeremydoc
09-16-2015 11:31 PM
peruviann
09-14-2015 06:35 AM
Quick Reply: Can i hit 450+/-??
