Cant get rid of turbo flutter/comp surges Help
Old 09-30-2011, 04:07 AM
  #41
ScionCREW's Avatar
Originally Posted by Vindiesel075
Hey guys i have a problem with turbo flutter and comp surges at low boost. When i shift at 6 psi(my max) its fine but anywhere below 4 psi i get ____ty flutter after my bov action.
Heres my current set up
Dezod Turbo kit
Turbonetics turbo charger
HKS BOV ver 1 (adapter pipe that is 2.5 in into 2.25 in charge pipes) It is located just before the throttle body and is at the softest adjustment
Tial Wastegate
My vac lines are 5/32 ID . I have one running from comp source on the turbo to the side port on the wastegate.
I have a vac block which is has my throttle body line running into it. Along with my bov, boost gauge (aem digital) and AEM FIC.
Current set up makes 22 in of vacuum at idle 24 to 26 at deaccel.
I used to have a greddy type rz that fluttered as well
any suggestions?
Heres what i am working on now....
Getting a 2.25 in adpater pipe and moving it closer to the intercooler
Any other suggestions will be appreciated
Thanks!
the pic is of the set up with my greddy
try moving you vacuum source away from your throttle body. tie in to one of the vacuum lines on the opposite end of the manifold. your flutter may be coming for the Evap solenoid.
ScionCREW is offline
Old 09-30-2011, 01:50 PM
  #42
Vindiesel075's Avatar
OK will do thanks guys
Vindiesel075 is offline
Old 09-30-2011, 05:03 PM
  #43
Music City Scions
rhythmnsmoke's Avatar
Originally Posted by Syldrin
the tial and turbosmart are made to stay open at idle and close under posotive pressure is why they work so well.
+1 on pearl exhaust has nothing to do with flutter.
Turbosmart is not open at idle.
rhythmnsmoke is offline
Old 09-30-2011, 05:30 PM
  #44
Syldrin's Avatar
really? i thought it was built like the tial. so it's just like any other bov?
Syldrin is offline
Old 10-01-2011, 03:00 AM
  #45
if im correct because of the MAF we can have the bov be open at idle....its basically like having an intercooler pipe leak really....
Old 10-01-2011, 03:47 AM
  #46
Music City Scions
I'm on a blow-thru setup (PTuning Spec RS).
Old 10-01-2011, 03:51 AM
  #47
ScionFred's Avatar
If any BOV is open or fluctuating at idle, it requires adjustment until it remains firmly closed. The only possible exception would be a recirculated or filtered BOV located before a blow-thru MAS.
I'm done...
ScionFred is offline
Old 10-01-2011, 04:08 AM
  #48
haha me too and i have to edit my post sorry guys i meant to type we CANT have it open my bad lol
Old 10-01-2011, 04:08 PM
  #49
browniemxn's Avatar
You can have it open as long as you have a recirculated setup or like Fred said "located before a blow-thru MAS".
My Synpase setup is sucking in air at idle, it is connected after the MAF sensor. As long as the metered air is accounted for you will be ok.
I would also suggest if using a MAP sensor to find a singled out tap to put it on. You can tap one directly to your intake if you have to. Other sources using your vaccum can jack with the sensor reading correctly. If I could I wouldn't us a vaccum block at all and run each system part or sensor their own source. Very much like the intake in the picture.
Attached Thumbnails Cant get rid of turbo flutter/comp surges Help-evointake.jpg
browniemxn is offline
Old 10-02-2011, 12:53 AM
  #50
crush02342002's Avatar
here is my two pennies
hks ver 2= pretty good out of the box for higher boost, low boost will cause a bit of flutter and as it gets older will flutter much more.
hks ver 3= a bit better than the version 2 but will flutter slightly on low boost. havnt had one around here long enough to see how it does as the miles rack up.
synapse= they do the job but they seem to me more hype than anything, Iv had one apart and i will not own one after seeing its seals. The seals are thin o-rings inside a chambered piston which would wear out much sooner than one that uses a nomex diphragm.
EDIT* Iv had the synapse wastegate apart, not the bov. however I have had dealings with their bov and they seem ok as long as they are hooked up properly.
turbo xs rfl= leaky leaky little bastards, they use a brass piston that doesnt seal at all. However if your just looking for something that is loud look no further...lol
greddy type rz= mine leaks somewhat from the valve seat no matter how much i adjusted the spring tension. If I put too much tension on the spring it will flutter at 20psi, correctly adjusted it works fairly good at high pressures. low boost however will cause flutter. Its a give and take on this one.
All of these iv delt with at one time or another and iv learned most dont do very well on low boost (1-8psi). All that are adjustable need to be adjusted.
crush02342002 is offline
Old 10-02-2011, 01:03 AM
  #51
XPRTc's Avatar
I'm late, but the TiAL should be closed during idle...
XPRTc is offline
Old 10-02-2011, 02:07 PM
  #52
Thanks Crush you are always a huge help. I appreciate it man Thanks!
Old 10-02-2011, 02:39 PM
  #53
browniemxn's Avatar
Vin! I totally skipped over part of your intial post where you mentioned 5/32 ID vac lines. Most auto-manufacture specs specify: nothing under 3/8 vac lines are to be used for proper sensor operation. I know being a dealer mechanic isn't the same as a performance shop mechanic but small vaccum hoses cause a great deal of problems.
That 5/32 ID vac hose may be too small. Have you tried anything bigger?
Old 10-02-2011, 04:45 PM
  #54
Yes actually I tried 7/32 no difference though but that's what led me to try something smaller to maybe get more vac pressure
Old 10-02-2011, 05:43 PM
  #55
no problem vin
JonathonK
16
02-20-2016 05:12 AM
tckid21
01-09-2016 09:19 PM
Scionxa180
09-24-2015 03:51 AM
brett561tc
09-15-2015 06:33 AM
ilikepinktacos
07-11-2015 10:20 PM
Quick Reply: Cant get rid of turbo flutter/comp surges Help
