Cant hit full boost
Old 02-25-2009, 12:18 AM
  #41
rozz-tC's Avatar
Originally Posted by olaHalo
UPDATE
ive confirmed that my problem isnt the wastegate flange gasket
ive just tested the car, and it still has the same problem after ive replaced the gasket
I would pull the wastegate apart and take a look, your plunger could be stuck half open or something.
rozz-tC is offline
Old 02-25-2009, 12:22 AM
  #42
olaHalo's Avatar
UPDATE
from the look of it, it opens with just an allen wrench rigth?
ive never taken one apart
how would i know if its stuck or not? push it and see where it stops?
it has to still be opening and closing, it just seems to be opening early
olaHalo is offline
Old 02-25-2009, 12:27 AM
  #43
rozz-tC's Avatar
Well the easiest way ive found is grab a C-clamp, tighten it down on the "dome" first, then undo the allen bolts. If you dont clamp it the spring will give you hell when you are tryin to unbolt it.
Once they are all out, loosin the clamp and it will come apart, make sure the spring is in one piece (ive seen them snap) and that everything looks in good condition.
rozz-tC is offline
Old 02-25-2009, 12:36 AM
  #44
olaHalo's Avatar
thanks for the replies rozz-tC
but i have another update!
haha
so i just did the soapy water test, and exhaust IS in fact coming out of the wastegate to manifold flange.
ive tightened it down as hard as i can and its still coming out.
could it be warped? or does the gasket have to be a certain way?
olaHalo is offline
Old 02-25-2009, 12:53 AM
  #45
rozz-tC's Avatar
could be warped, but to be honest a small leak there isnt going to limit your boost like that, my gasket fell out, completely. i still built boost, took alot longer to spool but would still get there.
Still something you wanna get fixed im sure, but not the cause of your main issue. once you get your issue fixed you can take it to a machine shop and they will make it true pretty cheap. Take both the manifold and WG, they will make it so you dont even need a gasket lol.
rozz-tC is offline
Old 02-25-2009, 02:02 AM
  #46
purevision01's Avatar
did you ever put the cardboard between the wg and flange?
purevision01 is offline
Old 02-25-2009, 03:43 AM
  #47
olaHalo's Avatar
tried, but the screws arent long enough
and when i took the wastegate off, i noticed the gasket was burned and i assumed that was the problem.
olaHalo is offline
Old 02-25-2009, 04:46 AM
  #48
aen
aen's Avatar
if it actually burned that means that the gap was pretty wide
aen is offline
Old 02-26-2009, 01:22 AM
  #49
olaHalo's Avatar
well it was black on the top half. may have not actually been burned.
i tried putting the wastegate on without a gasket like you suggested and it still leaked.
i still havent tried a brand new one yet.
the gasket i used was the one from my dump tube
if its warped, how would i be sure of it? put a straight edge or something?
olaHalo is offline
Old 02-26-2009, 02:13 AM
  #50
Troys_tc's Avatar
you can run rvt between the wastegate and mani, and wastegate and downpipe, that should fix that leak
Troys_tc is offline
Old 02-26-2009, 04:33 AM
  #51
I dont know if regular rtv would withstand 900+ degrees celcius. That stuff is usually only good to about 600F max.
Old 02-26-2009, 10:19 AM
  #52
crush02342002's Avatar
i think the copper rtv can withstand the highest temps of all the rtv's but still i dont think it is rated for 900+f, could be wrong though. I noticed i have slight leaks here and ther that i need to attend to so id like to find something i could coat my gaskets with that would hold up.
crush02342002 is offline
Old 02-26-2009, 10:55 AM
  #53
Troys_tc's Avatar
It will, tubonetics recomends put rvt between the hot side of the turbo and the downpipe, check out there turbo install direction on there website, and I run it on my wastegate with no problems
Troys_tc is offline
Old 02-26-2009, 04:03 PM
  #54
1UP Crew
ippskidder's Avatar
I'm gonna have to look into that, lol.
ippskidder is offline
k1114
43
03-01-2023 03:08 AM
eric29
15
04-26-2016 07:27 PM
knepart
Scion FR-S Forced Induction
04-25-2015 02:48 PM
cid_mcdp
01-05-2015 02:45 PM
spawnconnery
12-18-2014 08:38 PM
Quick Reply: Cant hit full boost
