car not starting...
Originally Posted by Byta27
me and matt had the same prob listen to us check that fuse guratee that is it just make sure u unlug that o2 and get it fixed before putting in the new fuse cause on the way home it will prob blow again.
yes, it started. somehow reseting the ecu fixed whatever problem it was. it might have been scion security disableing it? whatever it was, the ecu wasn't letting the injectors flow because in the morning i didnt smell any fuel. didnt check for ignition but that might have been it. so i know fuel was cut by the ecu.
but ya, car works perfectly fine now after the ecu reset due to checking fuses. it is NOT becuase of the secondary o2 problem that prototype and byta are having.
not to much good? most of the people here have had i would say a decent experience. this was my only major let down so far, but it really wasnt since a reset fixed whatever it was. and its an electrical problem (most likely TT is at fault but i wasnt using it under normal operation) and nothing wrong due to the actual turbo kit itself.
TheTripleC
01-04-2015 06:46 PM
