Car smoking on decel
Old 08-02-2011, 05:45 PM
mmmpshh's Avatar
Default Car smoking on decel
Need help folks. Car is smoking ONLY on decel. It does it whether its in gear or not no matter how fast im goin. No oil in IC piping. Turbo has very minimal shaft play. I have a oil catch can with a breather on it. Car still drives fine as far as performance. Its a 60-1 by garrett which Im the 2nd owner of and I know the car this turbo was taken off of. Smoke is white in color and it is a ish load of smoke and smells like oil. I wanna fix this issue without spending a whole lotta money. Any ideas?
mmmpshh is offline
Old 08-02-2011, 06:23 PM
MrBurrito's Avatar
well to be safe take of you down pipe to check and make sure no oil is coming out the turbo. but it sounds like the problem i was having where the car would smoke on decel, its mostly because you're turbo is using up the oil on accel then as the oil accumulates because of the pressure it smokes on decel that's just my theory though. ended up getting a new turbo anyways and no more smoke. but like i said check you down pipe and if worse comes to worse take your manifold off and make sure the oil isn't coming out of your exhaust ports i've seen built motors with this problem, probably thats not the case but better safe then sorry
MrBurrito is offline
Old 08-02-2011, 06:43 PM
Syldrin's Avatar
put your hand on the bottom of the turbo and feel for oil. you could just be leaking out of the exhaust housing. also if it's not the turbo it could be your head gasket. and you're just noticing it on decel but it could very well be smoking under acceleration you just cant notice it.
Syldrin is offline
Old 08-02-2011, 07:23 PM
mmmpshh's Avatar
will check and do all of that but I know its not smokin under accel, its ALOT of smoke. I hold it a diff RPMS for diff amounts of time and it always as soon as I let off the accelerator. I dont think its a gasket tho cuz it would be smoking all the time. There is no oil coming out of exhaust. My exhaust is like 18" long and pointing straight down... no oil forming and I dont feel a mist of any sort. No oil forming around the turbo either. I changed the return line yesterday and cleaned up dirt and oil and checked everything, no sign of leaking. I also flushed coolant and checked levels after running the car and no signs of coolant being consumed. Its really wierd and its ____ing me off to be honest. I will do a leakdown test tomoro and see what that tells me. I would think its turbo seals but wouldnt it smoke under accel and not decel?
mmmpshh is offline
Old 08-02-2011, 07:25 PM
trd07tc's Avatar
sounds like valve seals or worn rings
pull the dipstick while the car is running and report
trd07tc is offline
Old 08-02-2011, 07:29 PM
mmmpshh's Avatar
report what? doesnt seem to be anything unusual
mmmpshh is offline
Old 08-02-2011, 07:53 PM
Syldrin's Avatar
he ment tell us what you find. if you see nothing its not rings if you get smoke out of the dip stick its rings
Syldrin is offline
Old 08-02-2011, 08:07 PM
mmmpshh's Avatar
no smoke out of dip stick
mmmpshh is offline
Syldrin's Avatar
your car doesnt seem like it's smoking under acceleration because its burning most of the oil off.
Syldrin is offline
Old 08-02-2011, 08:08 PM
mmmpshh's Avatar
^hhmmm... maybe
mmmpshh is offline
Old 08-02-2011, 08:15 PM
Syldrin's Avatar
no not maybe. i'm telling ya
Syldrin is offline
Old 08-02-2011, 08:17 PM
mmmpshh's Avatar
wasnt that kinda maybe... more thinkin of ur right. lol
So anything else I can check? Cant do a leak down test till tomorrow so kinda wanna do/check all that I can now.
mmmpshh is offline
Old 08-02-2011, 08:21 PM
trd07tc's Avatar
most likely the turbocharger or valve seal wear
trd07tc is offline
Old 08-02-2011, 08:26 PM
mmmpshh's Avatar
^ thats what Im thinkin... hopefully just turbo. Anyway to narrow it down to turbo as of right now?
mmmpshh is offline
Old 08-02-2011, 08:33 PM
Syldrin's Avatar
was their oil underneath it? like on the turbo itself?
Syldrin is offline
Old 08-02-2011, 08:38 PM
mmmpshh's Avatar
no, and its a brand new oil return line as well so thats also good.
mmmpshh is offline
Old 08-02-2011, 08:39 PM
Syldrin's Avatar
same oil pan?
Syldrin is offline
Old 08-02-2011, 08:42 PM
mmmpshh's Avatar
same oil pan which I actually dropped about a week ago and cleaned up and nothing seemed to be outta place
mmmpshh is offline
Old 08-02-2011, 09:47 PM
crush02342002's Avatar
do a comp test and leakdown test if you have the chance.
crush02342002 is offline
Old 08-02-2011, 09:53 PM
mmmpshh's Avatar
cant do tht till tomorrow
mmmpshh is offline
Quick Reply: Car smoking on decel
