CarbonXe is boosted. 287.2/272
Old 11-30-2008 | 12:43 AM
  #1581
Ace83's Avatar
Ronin Scion
your qtp is after your O2 sensors right? haha
Old 11-30-2008 | 12:49 AM
  #1582
crush02342002's Avatar
it goes primary o2 on the down pipe secondary and uego on the s-pipe and qtp on the mid pipe
Old 11-30-2008 | 12:52 AM
  #1583
aen's Avatar
aen
the camshaft sensor wire also needs a resistor
Old 11-30-2008 | 01:52 AM
  #1584
all iv heard is the resistor for the cam sensor ( you join the cam mag- with the cam mag+ with a resistor) but i havnt heard of anyone using it for crank sensor which is the code i got (crank sensor malfunction) but i went ahead and did the cam resistor thing and cleared the code. i havnt had the cell come back on for that, just to check to see if the resistor really fixed the problem i removed the resistor to see if the code came back..............well it never did........thats why im really confused right now. so after all that i was thinking maybe i had a short in the fic harness, most likely it would be the wires for the crank sensor. just to be sure i checked all the wires with an ohm meter and every wire was good to go. its still possible that maybe i didnt have the connector pluged in all the way but i checked those too. idk all i know is that everything is going ok except for running lean at idle and on light excel in 1st-3rd
Old 11-30-2008 | 02:01 AM
  #1585
i will say that jon's map is mean in boost though, even at 7psi its a beast. mr. meaty's tune aint got nothing on jon's imho. but phil's tune is consistent and great for warmer weather
Old 11-30-2008 | 10:59 AM
  #1586
B_Real45's Avatar
There are two resistor mods.. cam sensor and crank.
Old 11-30-2008 | 12:35 PM
  #1587
crap i only heard of one, hmmmmm that changes things...lol
is it the same process (connect crank mag- & crank mag+ with a 2.5 ohm 1/2 watt resistor)?
Old 11-30-2008 | 12:37 PM
  #1588
some one should make a sticky on this info...lol
Old 11-30-2008 | 01:00 PM
  #1589
B_Real45's Avatar
Yeah - just a 2k ohm resistor on Crank MAGI- and Crank MAGI+
Old 11-30-2008 | 01:06 PM
  #1590
sweet ill look into it, thanks alot mang
Old 11-30-2008 | 02:35 PM
  #1591
ippskidder's Avatar
1UP Crew
I didn't know there were 2 FIC mods either >.<
lol
Old 11-30-2008 | 05:44 PM
  #1592
aen's Avatar
aen
yea there are 2 cam and crank thats what i was trying to say lol.
Old 11-30-2008 | 05:47 PM
  #1593
hey hieu you should sticky that kind of info or something cause i couldnt find it when i searched.
Old 11-30-2008 | 05:50 PM
  #1594
B_Real45's Avatar
Crush you should read up on the aempower forums.. they have all the info there.
Old 11-30-2008 | 05:52 PM
  #1595
iv gone ther a couple of times but i really dont like the layout of it. I suppose i should do some reading up on it though.
Old 12-01-2008 | 02:01 PM
  #1596
CarbonXe's Avatar
My tune official hates me now. I began adjusting the O2 map and dropped the boost to omfgmycarisslow mode and it's just UBER rich everywhere.
Actually, not everywhere. Idle is flawless and 4500+ RPMs holds a very nice solid 11.
Old 12-01-2008 | 02:16 PM
  #1597
rhythmnsmoke's Avatar
Music City Scions
^^why you turn it down again?
Old 12-01-2008 | 02:48 PM
  #1598
CarbonXe's Avatar
To play it safe until I get the new clutch/boost controller/tune.
Old 12-01-2008 | 02:50 PM
  #1599
ippskidder's Avatar
1UP Crew
I'll be richening it up tonight, and aiming for 12psi ^^
I just have to get the duty cycle on the apexi tuned a little better. Its such a PITA, lol.
Old 12-01-2008 | 03:04 PM
  #1600
Music City Scions
^^I am about to turn mine back to 0.8/0.85 Bar of boost. My injector duty cycle on 0.7 Bar is like 38%...lol. Got plenty of injectors now.
Quick Reply: CarbonXe is boosted. 287.2/272
