Compression Test Results
thats prolly it then...lol
cause at those pressure levels tends to mean piston damage or valve damage.
bring the car to operating temp and try it again. I bet your readings will be higher
they should read close to 180psi@ op temp...if any of the pistons are 10% less than the others you may have a problem. make sure the hose is tight and dab a little oil on the o-ring to make sure the hose seals.
TheRealShark
Scion tC 2G ICE & Interior
08-05-2015 05:08 PM
Subaru86
07-31-2015 04:33 AM
