Copper Exhaust Manifold Gaskets? Lancaster CA Help?
Old 03-20-2006, 01:51 PM
ScionDad's Avatar
Default Copper Exhaust Manifold Gaskets? Lancaster CA Help?
Once again, my OEM manifold gasket is leaking and I'm sick of it. Even when I had the Megan header on, it friggin leaked. Toyota has a sense of humor when it came to designing this manifold bolt pattern. Sorry, but 5 bolts covering 4 cylinders doesn't work well. IMO, great seal means 8 BOLTS.
So, I have been hunting down first rate copper gaskets that seal...even on irregular surfaces and came across these guys.
http://www.scegaskets.com/products/procoppex.html
Excellent gaskets and run less than $30 each....I just need to locate a dealer and see if they even make them for the tC yet.
If anyone has any other options...post them up.
<EDIT>
They need a manifold or header to design the gasket. They don't want to work from the OEM gasket I offered to send becasue their position is...they will just duplicate their problem. If anyone has a header or manifold.....
Phone Numbers:
661-949-0083
1-800-GASKET-0
1-888-GASKET-1
Fax:
661-940-4883
Address:
SCE Gaskets Incorporated
1122 West Ave L-12
Lancaster, CA 93534
ScionDad is offline
Old 03-20-2006, 03:11 PM
ZPIracing's Avatar
we are in the process of having these made but no timeline yet at all....
ZPIracing is offline
Old 03-20-2006, 03:21 PM
ScionDad's Avatar
That would be excellent.
ScionDad is offline
Old 03-20-2006, 03:49 PM
peteyd's Avatar
ok good its not just me noticing this! ill see what i can find out scion dad.
peteyd is offline
Old 03-20-2006, 03:55 PM
ScionDad's Avatar
Yeah, even when I put the Megan header on, their cheap gasket leaked. Then I went with a new factory 1 and that leaked. Only thing left that I know of the copper with crush rings.
ScionDad is offline
Old 03-20-2006, 03:56 PM
peteyd's Avatar
i have one in my area bout 15min from me ill call them up to see if they do/can make it if they do. and ill let you know!
peteyd is offline
Old 03-20-2006, 04:07 PM
peteyd's Avatar
Ok i called they said no ....i just emailed the company see if they can help us out.
peteyd is offline
Old 03-20-2006, 04:18 PM
ScionDad's Avatar
Yeah, I've made several calls so far this morning. After reading alot of other issues for leaking exhaust gaskets...it appears that the occasional backfire can be attributed to this as well.
ScionDad is offline
Old 03-20-2006, 04:37 PM
PghtC's Avatar
Yeah, SCE makes good gaskets. A lot of my friends that build big HP motors use them.
PghtC is offline
Old 03-20-2006, 06:19 PM
ScionDad's Avatar
Yeah, they make sweet gaskets. They even state they will do custom gaskets...but no luck so far,
ScionDad is offline
Old 03-20-2006, 08:09 PM
PghtC's Avatar
you will probably be able to get them to make you one, but it will be pricey since it is custom. Good luck.
PghtC is offline
Old 03-21-2006, 05:36 AM
EnderSavesTheDay's Avatar
Sorry to be a bit noobish about this but what kind of symptoms would a leaky gasket show?
EnderSavesTheDay is offline
Old 03-21-2006, 01:38 PM
ScionDad's Avatar
Occasional backfire is possible and black soot on the engine block.
ScionDad is offline
Old 03-22-2006, 06:20 PM
ScionDad's Avatar
I spoke with SCE this morning and he said they would be very interested in designing a copper gasket for the Scion tC.
I offered to send an OEM gasket, but he said he would prefer to have a header or manifold to work from. If he goes by the OEM gasket, he may just duplicate a problem since it is unusual to have a 5 bolt system. Toyota is using alot of surface area to seal instead of direct cylinder pressure from bolts.
Anyone in Cali able to help?
1122 West Ave L-12
Lancaster, CA 93534
ScionDad is offline
Old 03-22-2006, 06:53 PM
peteyd's Avatar
Scion Dad I still have my stock mainfold sitting in my garage. If they want I can ship it to them.
peteyd is offline
Old 03-22-2006, 07:14 PM
peteyd's Avatar
Scion Dad. Im on the phone with this guy named steve and he says they have it. It part of thier titan series! he is checking on prices now for me.
peteyd is offline
Old 03-22-2006, 07:30 PM
ScionDad's Avatar
peteyd, huge help
ScionDad is offline
Old 03-22-2006, 10:11 PM
OuterHeaven's Avatar
Sciondad I have a stock header sitting around the garage right now (I live in San Diego) and I could probably lend it to them. Also when I get my ZPI manifold back from ZPI I may be willing to lend that instead or do they need the car also?? Anyways PM me if you are still interested.
OuterHeaven is offline
Old 03-24-2006, 01:54 PM
OhioScions
ScionLawyer's Avatar
Bump
ScionLawyer is offline
Old 03-24-2006, 03:07 PM
ScionDad's Avatar
Originally Posted by ScionLawyer
Bump
Cool. I believe there are several people sending in and hand delivering exhaust parts for them to develop our gaskets. Word has it, should be ready in a month...
ScionDad is offline
Quick Reply: Copper Exhaust Manifold Gaskets? Lancaster CA Help?
