couple quick zpi questions
okay i'll keep this short. basically, i plan to order a stage 0 kit over the summer but i have a couple questions regarding options.
1. HKS SSQV- i need to get the optional flange with that, right? also, what size flanges do we use? 50mm, 60mm, or 65mm? what's the difference?
2. zpi pre-tapped oil pan- i can get it with oil line size of -8, -10, or -12. which should i get? what are the oil line sizes in our tCs?
3. emanage blue- is there a harness available? ZPI's selection of harnesses seems to be for the emanage ultimate. that isn't compatible with the blue is it? if there's no harness, i just splice the wires in, right? side note: if i get the pressure sensor upgrade, will i need a retune or will it just run better off of the base map i'd already be using?
alright, thanks for the answers. i've learned a LOT by searching around the forums but i still had these questions.
if you buy everything together they will set you straight. The bov needs the flange welded on and they will do it for yu. The pan will need to come with w/e size they provide in the turbo kit. as for the emanage harness why dnt you just call them? and dont forget an a/f guage that needs to be welded int the downpipe, which they will do it you rder it all from them at once.
the stage 0 kit comes with all the stuff to tap your own pan, you don't need to order a pre-tapped one.
-Chris
ShadowMage
16
07-25-2004 07:02 PM
