cracked exhaust manifold
see i told everyone it doesnt have to do with spring bolts cuz i had spring bolts on my first dezod mani and it still cracked. Go to a local exhaust shop and they can weld it up for you, its pretty cheap to.
yes sir, i believe there is another set at the end of the spipe and the beginning of the midpipe before your muffler. If you are using those as well, you might want to see if Paul might warranty the manifold. The worse he could say is no, so why not right?
i have had the kit for over a year and i was not the original owner i bought it off somone here that only had it for 500 miles before he went into the service. i am talkign too paul at the moment.
soflotc i talked to a muffler shop around my area and they said that they could weld it but since its stainless steel they do not know how long it will hold since they only have welding rods with 75% argon not 100%argon
nate
nate
did you hit up speedway in upland? they usually do good work and are fairly priced. look for a place called atd components in upland, if they dont weld it themselves they will show you someone who will.
good luck. i hope you get it figured out.
what part of upland are you from? i used to live right above 13th on mtn. i havent seen any other turbo tcs around
darkshadowofxdeath
11-22-2014 06:46 AM
