Custom Supercharger Shafts [Pics of damaged shaft inside!]
Decided to make an new post for this because other post was getting cluttered.
We now have 2 thousand dollar paperweights. What ever the case is Vortec, TRD, and PSE Superchargers are all a bunch of DBAGS. But I did find out that PSE Superchargers was hired to figure out the problem with the Scion TC supercharger.I also found out some interesting info talking to Ed Martinez the founder of PSE Superchargers (got the number from Bob Garner Supervisor of TRD). After talking to him and using my superb speaking skills, it slipped out of his mouth that the shafts of the TRD Scion TC superchargers (Mostly the 06) were not hardened correctly from the factory. So my friends this is F*ed up. No matter what bearings you use the original shaft will always spin inside the bearings because the metal is too soft. Gompka and I will soon be producing our own custom shafts. Most likely in partnership with kikcaffine (bearing dude) we will be making more than a couple for sale with sweet bearings from kikcaffine. I will get the first two made this coming week and put it in asap for testing. FINALLY an option B. Please call Bob Garner from TRD and tell him what you think of this supercharger haha. I have been calling everyday for the past month.
Our shafts will be full shafts, not hollow pipes, and will be fully hardened at a machine shop that makes parts for Boeing. We will make these as low cost to you as possible but keep in mind they want over $500 at PSE to "diagnose" your supercharger and give you the same ____ty shaft as you had before.
Just wanted to add that its probably NOT a good idea to run without the heat shield. It does a lot to keep the shaft/bearings cooler. You can run header but they have to fit inside the heat shield or they have to be heat wrapped crazy.
Here are pictures of my supercharger shaft for anyone who has taken it apart or will and has similar problems.
The gap you see there shouldn't be there, the bearings are supposed to be hydraulically pressed on and never move
The bearings slide on and off easily using just my hands!
The bearings are still fine, i took off the rubber cover and there is still grease inside and they spin pretty freely. The lip you see on the bearings was caused my the ring on the shaft as it was spinning, other than that bearings are not the cause of the problem from what I can see here
thats what mine looks like this should be a issue that toyota/scion/trd should take car of and recall all 05/06 s/c systems that is what a good car company would do we as the buyer should not be stuck to fix toyota/scion/trd mistakes
Ok I have setup a meeting with the shop doing the shafts on friday, we will double check all the measurements and figure things out about what material will be used on the shafts. Hopefully I will have the first 3 shafts done on Saturday, then i will test it out on my car asap and let you guys know. So streettimetc just wait a little longer and you will be able to be up and running again. I won't know a price until friday or Saturday so no definitive numbers yet.
I made a new post with a new update, please check it out asap as I need to make a decision by sunday or be foreced to wait another week.
link https://www.scionlife.com/forums/vie...881125#3881125
Originally Posted by bennyboopy
You guys may also want to look into doing a bit of hardness testing on both shafts to see exactly how much stronger the new ones will be.
Any word from the machine shop?
rain7905643
12
06-13-2018 05:34 AM
rain7905643
03-14-2015 12:48 AM
CONCRETETC
02-09-2015 08:05 PM
