Custom Supercharger Shafts !
#381
Hey Gompka, I think there might be a problem then.
The housing has a gap which I can't seem to get closed. I think the end of your shaft might be too long for the housing. Do you think once I screw down the 3 bolts that hold the housing close, the gap will close?
The black cylinder that the 12 pt bolt goes through does bottom out on the shaft. You didn't make the central hollow tube of the shaft any longer right? The extra length you put on the ends of the shaft should be taken up by the length of the pulley and the length of the black cylinder the 12 pt bolt goes through right?
#382
You seem to be having alot of issues!!
I installed on in about 45 min no issues.. wonder whats up
#383
#387
just wanted to say that i have a little over 5000miles on gompka shaft and bearings with no issues i also did the grease fitting trick. and im running the ceramic bearings on the s/c side. with this setup the car seems to have less drag out of boost witch leads to better throttel responce while out of boost. im verry happy with this shaft far better than oem. its a s/c must!
#388
#389
I just got off the phone with Gompka and he got me the sale price. I have been bad about checking the site. I plan on getting a new s/c under warranty, then turning around and voiding it with a new pulley and shaft. i want to add the grease fitting to the pulley end of the shaft while i have it all apart. anybody running a 9.5 with gompka's shaft and grease fitting? what sort of life expectancy for the shaft bearings with this setup, should i expect? thanks guys for all the years of good info, and thanks gompka for extending this great price a few more days!
#390
Just a reminder the sale price will be in effect untill Sunday night! Also any one else who has installed their shaft and has pics please send them to me and if anyone ran into any problems or recommendations etc let me know also.
#392
You should have cause they were on sale last week. The diy is complete, you do the same in reverse to get i back together. And the place you choose to press in the bearing will know how to do that. Someone is supposed to send me a video of how they put thier shaft on start to finish. If that video is better than what I have up I will post that one.
#393
Hey All,
Finally got the supercharger installed. Sounds good. Thanks everyone!
http://s6.photobucket.com/albums/y20...t=SSPX0147.flv
#397
I would like to make more, the problem is i needed to get 19 of these at once before, and I would need to get 10 minumum for a second run. That requires me to put a lot of cash upfront without any guarentee that the rest of these will sell. I have 5 of them left right now. If people show more interest in these after they are gone I'm going to have to do a pre-order type deal to get more of these made. So at that point once 5 people put in orders and give me 1/2 down or whatever it would need to be i would be able to make more. So your best bet would be to get one now while they are still guarenteed to be here unless of course you and 4 friends want to order them once i'm out of stock of these 5 lol
#399
Yup, if i was a big company and could afford to have some stuff sit on a shelf, then no problem, but i'm definetly not in a position to afford that.
#400
yeah im in dunn's situation, i don't need it quite right now, but i would love to pick one of these up. money is a little tight too also, and with christmas around the corner, its gonna be harder to come by with the money, but ill see what I can do.
