custom turbo kit!!! Dyno Sheet up update on pg.10
#41
Originally Posted by m6ar2cel6oTC
cool but its pulls like 29 degrees of timing thats crazy so once i am reflash the stock ecu wont pull as much and i would get more power out of my setup! we will see tomorrow buti have another question when i turn my car in tomorrow do i have to disconnect my emanage or can i leave it plugged up and if i have to take it out how would my car run since i am intercooled and have 550 cc injectors?
Not only would your car not be running right, but you DEFINITELY wouldn't be making 290whp.
#44
no i was running 240whp with 29 degrees being puled with 290 i think it was 19 degrees. i guess we will find out tomorrow hopefully!
As far as I know, we can't advance timing with piggy backs.
#45
cant we advance timing with fic or emanage? i thought we can, its just tricky coz we retard or advance starting from the stock ecu timing and the values we put arent the actual timing itself
#47
i ave the emanage. and he said he added timing so i dunno. ok here is the deal i went this morning to reflash my comp and i just got a call back from the guy saying that its not working! that tey cant reflash my comp back to stock! now what!!!! ANYONE WANT A REFLASH ECU FOR THERES!
#48
i think you can add timing i think it works like a spark hold if you iknow what im meanin so instead of altering the stock timing it holds it till the next one so that you can have more control maybe sounds good in theory right?
#49
when i had the emanage, i can see negative and positive numbers on the ignition map table so i assume the negative numbers are the degree retarded from the stock values and the positive are the degree advanced from stock values..
#50
#53
ok so went back to my tuner to smooth out the a/f a lil cause of the timing well its looking a lil better but couldnt exactly flatline it cause of the timing ofcorse lol. but i made more power i did alot of runs i just dont know how much lol but i did around 20 plus street tuned it cause my car kept stalling when i would hold the clutch down and let the rpm drop at high rpm's. so anyways i made 280 whp and 300 ft-lbs on like the 30 something run lol! on the graph it was the first run that i made 280 something on whp and ft-lbs and then the final run when we said ____ it no more lol.
#56
Originally Posted by B_Real45
What I mean is that he couldn't have pulled 29 deg of timing.. that would make the car utterly useless.
At most people pull about 1 deg per psi..
#58
man i have no idea what the program ws called all i saw it in the laptop. and it was plugged in my obd port.and it showed how much timing was pulled in degrees. it wasnt my tuners laptop that was used for that it was the guy that runs TNT from broward.
