cut out at WOT!!!!
cut out at WOT!!!!
i got my car tuned three different times changing different things, this is starting to be a expensive guessing game. i soildered my injetors in. they are 440cc. i got a walbro 255. still didnt fix problem. then i had custom dump tube made because the waste was dumbed into my downpipe to close to the turbo leading to much back pressure and cutting out. my car keeps cutting out around 4.8 rpm so he cant even finish my tune. what could be my problem this doesnt make sense to me.i hav a 08 boosted tc. manual. t3/t4 turbo
this thread is full of fail sorry
-why hasnt anyone asked what piggyback hes running
-the o2 sensor code is for the rear o2, thats not causing ish..
- the wastegate dump wouldnt cause it
ok so back to reality
OP what engine managment are you using, was it hardwaired or did you use a harness
also if you are using a aem fic try the resistor mod
I have Greddy ultimate it is a harness tapped into my ecu. I have one step colder iridium plug. The tuners shop gapped them for me. And I heard about a resistor mod but don't know if u can do it for my set up. Do u think it is because I have small injectors and pushing to much boost for them. I have 440cc and running ten pounds.
you don't need to do the resistor mod with the ultimate. you need to find out what gap they are at i bet they gapped them to far and when you hit full boost it's blowing out the spark.
Yes. It sounds like you may have other issues going on too but 440's are definitely too small for 10psi with a T3/T4. I'm running 440's with 6 psi and the inj's hit 90% IDC. Good luck.
