Cutout valves....on a turbo (Videos) NEW
Old 02-07-2007, 04:17 PM
  #61
Music City Scions
rhythmnsmoke's Avatar
Sooo....how about someone get a vid or sound clip or something. Worthless without a clip!
rhythmnsmoke is offline
Old 02-07-2007, 04:33 PM
  #62
tCrew_R's Avatar
lol i would have one had i not gotten the Dezod exhaust
I'll make some vids this weekend sometime.
tCrew_R is offline
Old 02-08-2007, 03:04 AM
  #63
yamaha16bw's Avatar
First page about half way down....greddy kit with QTP cutout.
yamaha16bw is offline
Old 02-08-2007, 04:27 PM
  #64
Music City Scions
It needs to be on YouTube..can't see crap on PUTFILE..
Old 02-08-2007, 10:45 PM
  #65
etsnet's Avatar
I got you man... just converted and uploaded to youtube. Here's both those videos on youtube for all that couldn't see.
http://www.youtube.com/watch?v=BgN2lQbg5IA
http://www.youtube.com/watch?v=KhTuXbKCtM0
etsnet is offline
Old 02-09-2007, 12:09 AM
  #66
Kumitsu's Avatar
I am going to order a Dezod kit in about 5days and i want to buy the cutoff valve from http://www.quicktimeperformance.com/QTEC/index.php
But i am confused, how should i order my turbo so i can use the QTEC cut off valve ?
1- Closed loop dump tube?
or
2- Open dump wastegate ?
Any other info is appreciated.
Kumitsu is offline
Old 02-09-2007, 12:41 AM
  #67
deep2k's Avatar
or
I would also like to know the answer to this. Open or closed?
deep2k is offline
Old 02-09-2007, 12:51 AM
  #68
pollup's Avatar
watching. if i install this on my car and get it tuned for the open downpipe, i will just run rich with it closed correct?
pollup is offline
Old 02-09-2007, 04:00 AM
  #69
yamaha16bw's Avatar
or
Closed watsegate.
The good thing about this is......its only open when you want it to be. Open wastegate dumps are insanely loud anytime you hit boost. Plus you only gain 1-5 hp from a open wastegate dump. The will yield more hp and is only loud when you want it to be.
Pollup,
Since we installed ours behind both o2 sensors our AFR's didnt change a bit. 11.4 closed 11.4 open.
Old 02-09-2007, 09:41 AM
  #70
pollup's Avatar
see mine will because i will have a more restrictive exhaust on there, the afr should change a little, it should go a little richer since your not able to move as much air. im pushing 10 psi spring, i cant even hit 10psi yet because of my exhaust and stock s pipe..
pollup is offline
Old 02-09-2007, 12:47 PM
  #71
yamaha16bw's Avatar
You prolly cant hit 10psi because of the boost loss from the intercooler and piping. I also have a 10 psi spring and have never gone over 8 psi due to boost loss. Every boosted car has this.
What kind of piggy back are you using?
Old 02-09-2007, 03:09 PM
  #72
Music City Scions
Closed watsegate.
The Opening and Closing of the WG is not controlled by PSI level. It's controlled by throttle position. You can boost without opening the WG. Therefore, it's not loud just because you are boosting. It's loud when your foot hits the floor.
Old 02-09-2007, 03:14 PM
  #73
pollup's Avatar
not true, on a 10 psi spring my car will be capable of 10.5 max psi. boost loss is not an issue. i am not hitting full boost because of my stock s pipe, its really restricting the flow. i chagned the muffler recently and that bumped my car up to right around 9 psi.
pollup is offline
Old 02-09-2007, 03:35 PM
  #74
Music City Scions
who are you responding to Pollup?
Old 02-09-2007, 04:24 PM
  #75
Team No Limitz
Simplyscion's Avatar
not true , the WG opens when the desired set boost level is achieved, then the open waste gate bleeds off the excess boost to keep it at the set level.
Simplyscion is offline
Old 02-09-2007, 04:35 PM
  #76
Music City Scions
Yeah, I know that dude. I wasn't being technical.
Old 02-09-2007, 04:53 PM
  #77
Team No Limitz
Old 02-09-2007, 04:57 PM
  #78
Music City Scions
the MESSAGE I was trying to convey is that you don't have to open the WG just because your boosting.....MEANING, it's not loud just because you are in boost. Partial Boosting will not open the WG.
Like I said, I wasn't getting all technical. I know what a WG's job is...
Old 02-09-2007, 05:11 PM
  #79
Team No Limitz
ya ya ya...your lucky its friday
Old 02-09-2007, 05:46 PM
  #80
Music City Scions
^^that depends on if you believe in luck or not....
Quick Reply: Cutout valves....on a turbo (Videos) NEW
