Decided to go turbo. Need your input on my build !
Ok guys/gals i decided to go turbo and keep at the low boost for daily driving. What i want to do i start preparing and getting parts that i need for it so i dont have to dish out 5-6K at once.
This is the set up i want to go with: TurboToyotas basic kit
INCLUDED:
-Turbotoyotas "shorty" ram horn style T3 flanged stainless steel turbo manifold
- Garrett T3/T4 spec turbo
-TIAL 38MM WASTEGATE
- 2.5" Stainless steel DP and S-pipe combo
-Greddy BOV
- 20 x 7 x 2.5 intercooler
- 2.5" aluminum chargepipe kit with couplers and t-bolt clamps-powdercoated black
-3" intake pipe with K & N air filter - powdercoated black
-Turbotoyotas vacuum block with fittings for wg, bov and boost guage
-Steel braided oil feed and return lines
-Set of 550cc plug n play injectors
-All installation hardware
I know i have to purchase boost gauge, oil temp, A/F gauge. EMS i'm probably going with AEM FIC . Also i want to get boost controller and have two settings 5 and 9-10 psi for racing. Will the AEM FIC handle two maps? ( i do need 2 maps runngin for it right ?) Any suggestion on what else should i get? gauges, parts for the engine etc.
BOV question: Should i go with greddy that offered with the kit or get HKS instead ?
I'm a noob at it , so have to start learning. Also, is there a reason of should i start getting gauges, boost controller now or maybe wait, maybe a better part will be produced.
What do you guys think ? I want answers/suggestion from all the ppl especially from those who are boosted.
I'm planning to daily drive at 5 psi and 9-10 psi for track/racing.
INCLUDED:
-Greddy BOV
you only need one map with the f/ic. have it tuned for say 8psi, and it will run good at 5psi as well. thing is, a boost controller can only go douple the rate, so if you get a 4.9psi spring, you could have one setting at 5psi and one at 9.8 psi. If your installing yourself, i'd go with the greddy bov cause the HKS is a pain to install, but I LOVE mine.
oh, and you need a gauge pod to.
Originally Posted by RusWolf
I need to chat with Todd, do you guys know if he can make a kit that will be able to pair with by-pass valve instead of BOV ? with bypass i will be "silent assasin "
I was under the impression that the turbo needed a BOV though... I dunno though, I'm a noobie.
Regards-
Todd
Greg S
07-21-2016 07:28 PM
hampton1100
05-28-2015 07:32 AM
jctc06
04-16-2015 12:11 AM
