Descendant Fuel Rail advantages
Ok so I have an opportunity to get sweet deal from a guy who is selling his Descendant fuel rail. My question is, does this provide any advantage to the fuel rail that comes with the TRD s/c kit? Or does that kit only come with bigger injectors, not a fuel rail?
It depends on how you look at it...
For someone running the OEM Fuel system key features would be the increase in bore diameter for fuel flow thru the rail and the 3/8NPT access port in the middle of the rail which could be used for Wet Nitrous system or fuel pressure gauge...and the OEM fuel adapter fittings which make the install EZ for any application.
Other benifits include the ability to later down the road or for someone upgrading there fuel system and adding a return line the DESCENDANT rail is a perfect addition! The rail has -10AN port fittings on both ends which can be used for a dual feed system and the 3/8NPT center port now works as a perfect center return.
If you have any other questions please feel free to call us.
since you're talking sc i take it that you aren't shooting for high numbers
which leads me to believe that you haven't looked into a return system yet.
which leads me to my next point.
you're wasting your money, you won't need it unless you go high hp.
steeze69
05-24-2021 02:57 AM
