//Dezod Fuel System//
So for those wondering how do I get LARGE injectors, at a decent cost and still have enough fuel for boost, look no further!
Dezod has come up with solutions to run injectors up to 880cc confirmed on a stock fuel rail. Injector possibilites are available up to 1000+cc. We have proven this exact set-up with 318_tc's car making 454whp. We are going to package together some parts in different stages to help you get to the power levels you want and need.
Package 1:
Injector Box
880cc injectors
Clips
Package 2:
Injector Box
880cc injectors
Clips
Fuel Pump & Install Kit
Package 3:
Injector Box
880cc injectors
Clips
Return Fuel System
Coming soon!!!!
Edit: We can realisitically fit 1000cc on the stock rail.
Package 1:
Injector Box
880cc injectors
Clips
Package 2:
Injector Box
880cc injectors
Clips
Package 3:
Injector Box
880cc injectors
Clips
Return Fuel System
Coming soon!!!!
Well Jeff brings a good point, some would argue over 350whp, while other would only justify over 425whp. The 880 leaves you room to grow and use less duty cycle to ascertain the power you want.
Originally Posted by yamaha16bw
What kind of pricing are we looking at? Ive been waiting for a return system to come out. Look for me to be first in line.
The aeromotive AFPR is a 1:1 setup. set your base FP, you can really dial in a good idle and a nice afr by setting the base FP. I like around 42 static pressure. once boost hits, you lose vac to the regulator and FP will increase 1:1 based on pressure.
a complete return setup can be done for about 300$. I'm actually putting together a DIY right now. all you need is the aeromotive regulator with can be had for 150$, a couple of aeroquip fittings and some -10 line.
if you want to go even cheaper and simpler, get pushlocks and all you do is cut your line and push the fittings on.
I'm going to be listing a step by step process and really it's not hard at all. no special tools needed.
