Dezod Motorsports: Engine management writeup
Old 06-28-2010 | 05:14 PM
DezodDon's Avatar
Originally Posted by rangerryda
I would love to see the APR in person. I'd like to see what it can do first hand. It sounds very similar to the Ultimate but very catered to the 2AZ platform in specific.
Exactly, and that's what Paul keeps forgetting to mention.
This unit, is specific for us, 2AZ-FE guys. Maybe Yaris too not sure yet.
The X1 might as well have been sold by TRD because it was designed by some old TRD engineers with many many months of testing and feedback from us here at Dezod. While everything else is universal and has to accommodate many different engines this is made and programmed for the Scion.
Might as well call it Toyodata.
Old 06-28-2010 | 05:25 PM
browniemxn's Avatar
Toyodata is what I call it. If I say APR people ask me what APR stands for and makes awful side conversation. I use "Hybrid" a lot rather than standalone. Forget using Parallel processing in a conversation many reply "so its a standalone right". I played this game with Dezod on the phone before I purchased the unit. I guess people just have to use it to know how awesome it is.
Old 06-28-2010 | 05:34 PM
DezodDon's Avatar
I think a new model name is in order
TcData!
Old 06-28-2010 | 07:16 PM
paul_dezod's Avatar
Scionetics
KAD
Indeed. Plus, look at how you and I are e-tuning easily. I can see all the data from every sensor and see exactly what happens.
RUn that revised spark curve Dan
Old 06-28-2010 | 07:22 PM
paul_dezod's Avatar
Scionetics
KAD
I do keep forgetting. This was the draft version at 7 pages of my life.....
Old 06-29-2010 | 07:32 PM
paul_dezod's Avatar
Scionetics
KAD
I have some revisions coming up soon. Stay tuned.
Old 06-29-2010 | 08:37 PM
06sciontcnda704's Avatar
Can you break down the Greddy Ultimate as much as possible for me (a complete noob to piggybacks) i just got one with my Zpi kit i got locally and would like to know all the add-ons i should get and anything u suggest
Old 06-29-2010 | 08:50 PM
m6ar2cel6oTC's Avatar
Search on here or google all the add ons for the ultimate.
Old 06-29-2010 | 08:59 PM
i see most of the add ons i just don't know what would be necessary on a scion tC and what people would recommend i do have the pressure sensor the guy threw that in for me with the PnP harness
Old 06-29-2010 | 09:00 PM
and i got a Greddy Turbo Timer
Old 06-29-2010 | 09:19 PM
Turbo timer has nothing to do with the ultimate. All you need is the pressure sensor. And if your tuning yourself the support tool, USB cable and the af target harness to tap that into your wideband and to your ultimate so you can datalog with the ultimate giving you afr readings str8 from your wideband.
Old 06-30-2010 | 02:54 PM
paul_dezod's Avatar
Scionetics
KAD
Unless GR fixed it with a new firmware or something, you could not run the AFR harness and the Pressure sensor simultaneously. It would create a weird error.
Old 06-30-2010 | 03:20 PM
ElevationTC's Avatar
Paul, i see alot of issues you were having with the emanage ult at one time.. How long ago was your last time with it.
Ive tuned about 5-6 of them now. And never had any of the issues that you spoke of. Not saying there wernt there. But maybe there has been a major firmware upgrade?
I tuned that car twice on the dyno.
One with pump 93 Dotted line
And e85 solid line... E85 run aborted when the (HORRIBLE) Nrg fpr seals blew apart causing e85 to spray everywere! (replaced with fuel lab <3)
Now i tuned a Aem fic just before that on the dyno and at 14 psi on 93 it only made 260whp. ( Smaller turbo, 2.5 EXH, Hotter IAT from not having blow through)
But from both system i always find the greddy much easyer to work with. Mostly due to fact AEMs map sensor is so senstive. Ur always tuning 3 rows vs the greddy were ur tuning 1 row Now i have fixed this issue with the aem by adding in a water filter and a reducer in line. Which GREATLY helps this issue from what ive seen!
If A/c worked flawlessly with the AEM EMS. I would talk everyone into getting one. TOTAL engine control. Not fighting any ecu. Great logger. Plus when you take the time to set it up. You have closed loop(o2 feedback) which has fuel trims to keep the car at correct afr's when needed. You have target idle, so the cars always making sure its idling at the proper spot. And was you take the time to setup the idle on and off. Tip in (Light blips) Are better then OEM!
This is not the full review im working on myself. but just a quick couple notes! I just signed up the the AEM tuner class. So ill be ready for when you guys release the new box :D
Old 06-30-2010 | 04:04 PM
I have both of them hooked up and running perfect.
Old 06-30-2010 | 04:12 PM
paul_dezod's Avatar
Scionetics
KAD
The more recent firmwares must have solved this issue. Good to know
Old 06-30-2010 | 05:56 PM
i want be tuning my ultimate taking it to a guy i know so all I need is the pressure sensor
Old 06-30-2010 | 06:03 PM
i want be tuning my ultimate taking it to a guy i know so all need I is the pressure sensor
I have a real greddy pressure sensor for sale..
or are you saying you dont need the o2 input!?
Old 06-30-2010 | 06:12 PM
paul_dezod's Avatar
Scionetics
KAD
The V2 EMS will be 100% better. The new software and hardware inside the box should allow us to make this much more seamless, however I would still elect an APR X1 over it for 95% of the users on this board.
Mike, we need to get you one to play with on a car. Trust me, you will fall in love with it.
Old 06-30-2010 | 06:27 PM
Im excited to see what aem tuner has to offer.. Hopefully they kept things logically as in aem pro. And didint take a step towards cryptic settings like hydra.
One thing i would LOVE to see would be a/c working. Ive been meaning time and time again to wire up everything except injector and coils back to oem ecu to see if it will take on DBW idle and a/c but, thats another day lol!
Is the APR unit similar to what im doing with ecuflash using the tactrix?
I guess im confused on hows it modding the internal rom, whens its external? Maybe you could shoot me and email with some more info? Sorry if its been posted some were i've been skimming scionlife latley!
Old 06-30-2010 | 06:50 PM
paul_dezod's Avatar
Scionetics
KAD
Tuner is a lot more straight forward, but the software still has some bugs. It freezes quite a bit and such......It has a built in help menu for a lot of settings now too. It has potential to be a real sick software, but needs more work IMO.
You do not want to do that with the AEM. There are 3 wiring changes and 2 box mods that need to be made for the A/C to work properly. That is the only real way to get the A/C working well through the stock ECU.
The APR more or less (in a nut shell) makes the stock ECU maps programmable. Without going into how it does it, I can simply tell you it works......and works well.
Quick Reply: Dezod Motorsports: Engine management writeup
