Dezod Motorsports Return Fuel System
As promised, is here. I was gonna release this on Friday, but I had some personal stuff I had to attend to outside of work. So here it is today!
The Dezod Motorsports Return Fuel System is a must for forced induction applications, and is designed to allow maximum fueling to your forced induction 2AZFE engine well beyond the capacity of the factory return-less fuel system.
Our kit is designed as a simple bolt-on with no modification to the factory cage assembly because we do all the work for you!
System components:
*Modified OEM in-tank cage assembly w/ -6AN fittings in place
*Genuine Walbro 255LPH Fuel Pump already installed
*-6AN lines w/ abrasion resistant black nylon braid (NHRA approved)
*Complete -6AN line assemblies with fittings installed
*Adjustable AEM Fuel Pressure Regulator
*Liquid-filled 100 PSI Max fuel pressure gauge
*Aeromotive 100 micron high flow fuel filter
*Dezod Motorsports CNC fuel rail
*Mounting brackets and hardware
One simple modification is required to the metal sending unit hold-down to allow for clearance of the new fittings. This kit is 100% bolt-on and is a fully modified return fuel system.
Other notable features:
*True 3/8” bore throughout the feed and return lines
*System does not use stock feed line as your return line
*No modification required on stock lines to use with our kit
*Complete stand-alone fuel system
*Easily returnable to stock (no buying new parts)
*No grinding or modification of the cylinder head is necessary
Pricing will be $699 complete as pictured with a modified cage assembly, rail, FPR, gauge, filter, pump, fittings, lines, brackets and hardware. This is a significant value over all of the competition.
To purchase
http://www.dezod.com/pd-dezod-motors...2azfe-fuel.cfm
System components:
To purchase
