Dezod S1 Installed...finally.
Old 04-07-2008, 01:26 AM
Mightygnu's Avatar
Originally Posted by 20tCDude05
My turbo kit has the intake pipe under the cold piping. I think it looks better like that.
Neil, he was having Intercooler issues as it was not his original Dezod intercooler, thats why the piping is like it is.
Mightygnu is offline
Old 04-07-2008, 01:36 AM
20tCDude05's Avatar
Oh, ok. I gotcha. If it works, cool.
20tCDude05 is offline
Old 04-07-2008, 02:10 AM
JL56TC's Avatar
here you go with the pix... its just a matter of getting all your piping to fit snug
JL56TC is offline
Old 04-07-2008, 02:54 AM
Phionix's Avatar
thanks...yeah i like it like that more - - but to all their own
Phionix is offline
Old 04-07-2008, 04:08 AM
anurok's Avatar
The only thing that concerns me now is the oil filter leak. Hope i can fix it in the morning. That and the fuel rail...
anurok is offline
Old 04-07-2008, 04:52 AM
Phionix's Avatar
get an oil catch can once u really start boosting - dont forget
Phionix is offline
Old 04-07-2008, 05:09 AM
Mightygnu's Avatar
Oil Catch Can really isn't needed..
Your actual filter is leaking? didnt seal enough?
Old 04-07-2008, 05:20 AM
anurok's Avatar
Yeah, it might be the filter or the plug...but there is some on the pan so I think it might be the filter not tightened down all the way
anurok is offline
Old 04-07-2008, 05:29 AM
Mightygnu's Avatar
I hope your pan sealed 100%.. if its the oil filter, just go get a new one, and put a little oil around the ring and put it on.
Old 04-07-2008, 05:31 AM
Phionix's Avatar
id like to differ...
from 3 turbo'ed cars that ive seen/engine bays
wat has happened with the oil that gets into the turbine/bearing area and burning it up = bad news
Phionix is offline
Old 04-07-2008, 05:42 AM
Mightygnu's Avatar
Let me rephrase, its not 100% necessary. I know plenty of people who are running there car just fine without the oil catch can, I at the same time was boosted for plenty of miles with no oil catch can, and I ran like a champ, plenty of people can vouch for that. Although a Oil Catch can is functional, it no means is it required. Also, I can say that it doesn't hurt to have one.
Old 04-07-2008, 05:44 AM
anurok's Avatar
I drove around for a month with that oil pan that way. It was done by a Pro garage...not myself.
anurok is offline
Old 04-07-2008, 02:05 PM
Enrique_Dezod's Avatar
Cool man. Glad to see she is rolling in dee right direction.........Finally!
Enrique_Dezod is offline
Old 04-07-2008, 06:12 PM
JL56TC's Avatar
Well I think that between my catch can and my oil cooler my turbo is fairly happy... I think if I went to a little lower boost it would run even better
JL56TC is offline
Old 04-07-2008, 09:09 PM
Scionetics
KAD
paul_dezod's Avatar
Glad to see she is in the right direction Paul!
paul_dezod is offline
Old 04-08-2008, 05:57 PM
anurok's Avatar
Yeah, I am as well! I have an appointment with Corner3 Garage to over look all of our install work and just double check everything then I have an appointment with Church's right after to get it all straightened out.
My biggest issue now is that leak between the waste gate and the downpipe =/ No matter how much I try and tighten it down the metals won't touch creating a gap. The exhaust leak sounds like a boat haha. It is also creating a lot of extra heat in the engine bay.
I more than likely won't be pushing more than 5-6 pounds with that leak. But honestly, if I get a boost controller...I don't want to push more than 5lbs.
Going to actually start a discussion on that now.
anurok is offline
Old 04-08-2008, 06:09 PM
Scionetics
KAD
paul_dezod's Avatar
I saw the gap. Did you try tightening down the WG first, then the dumptube?
Old 04-08-2008, 06:13 PM
JL56TC's Avatar
yeah I dono if I would even rin it like that...... I had to Take my Wastegate off and put it on the manifold frst and then put it on my downpipe to get it to fit... you could try that and see what happens. I know its a pain to do but whatever works
JL56TC is offline
anurok's Avatar
The gap is in between the Waste and and the manifold...but the downpipe is the thing that is causing the fitment issue because it is actually PULLING everything to the left.
Kind of a weird explanation but I don't know how else to explain it heh.
anurok is offline
Old 04-08-2008, 10:51 PM
soGone's Avatar
Nice to see you up and running man! glad you stuck with the kit!
happy boosting..
and as Joe said let us know if you need anything
soGone is offline
