Dezod S1 Kit Installd QUESTIONS RPM JUMPING
I just gotten the Dezod S1 turbo kit installed in my 06 5 Speed Scion tC, It was professionally installd and tuned. But after driving it, i noticed somthing that was going with my car. when my car is idling at a stop the rpms jumps from 600 to 1200. Is that normal?? And another thing i noticed is that it be stalling out sometimes out of no where when the BOV goes off??
IS THAT normal with this kit, can i fix these things??
THANKS FOR ALL YOUR INPUT
I GREATLY APPRECIATE THIS. . .
how do i recirculate the BOV?? The car is running pretty bad right now everytime i come to a complete stop n bring it to neutral the car stalls out!! WILL the synapse synchronic bov with the anti stall kit help it? Cause the rpms b jumping from 500 to 1100 n den wen it drops down to 500 it sometimes stalls out. . .
That's symptoms of a vacuum leak - and it's most likely from the BOV as others have suggested.
If you have the HKS SSQ BOV, then you can buy a recirculation adapter for it. All you need is an appropriate sized radiator hose going from the BOV to a port you'll need to get welded on the intake pipe to the turbo. Just make sure the port is AFTER the MAF.. meaning between the MAF and turbo inlet.
Originally Posted by Frisk00Azn
do anybody know where to buy a recirculation adapter if you do can you put the link onto this forum so i can get one online!!
THANKS
THANKS
05rs1
12-09-2016 02:18 PM
CrowJenkins
10-09-2015 10:47 PM
my06tc
06-25-2015 12:18 AM
