Dezod Turbo Tunning issue
I have a Dezod turbo
I have a situation that it doesnt' stay idle for more than 10 seconds.
THe check engine light is on..... Can anyone tell me how I can fit this using the greddy emanage?
Thanks
Thanks
Thanks for your reply.
I dont' know what kind of map you are referring to.
May I knwo if you have installed the split second PSC1 into your car?
I have sent you a message in AIm, can you reply?
Thanks
Thanks
i have the dezod kit with split second and emanage blue and had the same problem. my tuner found out there was a weird variable in the split second that was causing the idle to drop suddenly. i would have your tuner program the split second. hope that helps. when it happned with me it was only at cold start also, after the car warmed up it ran fine.
all you have to do is get it tuned unless you have other issues.. what kind of map did you have on your emanage? check for vacuum leaks or your maf sensor.. when I had my split sec, it made my tune richer and made my part throttle afr better.. idle was a lil better too around 14.4..
my06tc
06-25-2015 12:18 AM
TheTripleC
01-04-2015 06:46 PM
