difference in 2 psi
Old 11-11-2009, 01:35 AM
B_Real45's Avatar
Originally Posted by thendawg
Mines t'd off with the rest of my vacuum lines - including fic, guage, and bov - ive never had a problem with spikes although apparently some have. I only did it because my turbo compressor hadnt previousely been tapped when i got it and i didnt feel like taking the time to tap it lol I might sell my fic soon - when i go to manual swap im really wanting a standalone - i wanna rev to like 7k - hey on that note - does anyone know if you can up the redline to 7k by simply going with upgraded valve springs and retainers (no cams or valves). I know dezod sells the bc spring and retainer kit for like $280.
I've heard you can go 7k on the stock valve-train however I haven't done it myself.. not sure how long it can last.
Yes stronger springs and retainers will help - but you'll have to ditch the FIC.
B_Real45 is offline
Old 11-11-2009, 03:15 AM
crush02342002's Avatar
Lmao @ chinacharger
crush02342002 is offline
Old 11-11-2009, 02:02 PM
cburglb34's Avatar
Originally Posted by ScionFred
The easiest way to know is to look at the clamps that hold the comp housing to the back plate. 3x2 bolt = T04B, 2 half-circle clamps = T04E.
My CXR chinacharger has "T04E" stamped right on the comp housing but it's really a T04B.
two half clamps for me
cburglb34 is offline
Old 11-11-2009, 02:15 PM
highvoltage1's Avatar
is that half clamp for a t04e and a 3x2 clamp for a t04b true on all turbos?
Cause i got a turbonetics 50 trim and it has 3x2 clmps but it has E50 engraved in the comp housing.
highvoltage1 is offline
Old 11-11-2009, 03:02 PM
cburglb34's Avatar
think it applies for china
Old 11-11-2009, 04:50 PM
ScionFred's Avatar
Most T04B's are 2.75" in and 2.0" out, most T04E's are 3.0" in and 2.0" out. The best way to be sure is to measure your comp housing dimensions and cross reference to the turbo drawings at Turbonetics.
http://www.turboneticsinc.com/turbo_dimensions
I'm pretty sure that 3x2 bolt clamps will always be a T04B but I'm not 100% on that.
ScionFred is offline
Old 11-11-2009, 05:05 PM
Ok thanks. Well it is a t3/t04e then cause the in is 3" and the out is 2". Now i need to find out if its a stage II or III wheel. But im pretty sure its a stage II. Regardless it will give me the power i want.
Old 11-11-2009, 06:31 PM
cburglb34's Avatar
mine is 3inch in 2 out and i know it was a to4e because i barely fit and todd at TT said E housing have fitment issues
Old 11-11-2009, 07:14 PM
ScionFred's Avatar
A 3" comp inlet doesn't guarantee that you have a T04E. You need to measure your comp housing and compare your dimensions to the ones provided by Turbonetics to be sure. You can probably tell just by eyeballing the drawings in the link I posted.
Typically comp wheels are listed by trim and turbine wheels by stages.
cburglb34: It sounds like you do have a T04E.
Old 11-11-2009, 07:17 PM
Thats true but a t3/t04e turbonetics turbo has 3" or 2.75" comp housings. The t04b only has 2.75" according to there website. So I will do the other measurement you said but the info i just stated pretty much answers the question dont it?
Old 11-11-2009, 07:25 PM
ok well i checked your link as well and the comp is definitely a t04e hosuing. Every comp housign matches and i compared my measurements to the t04b and they are bigger than the t04b as well.
Old 11-11-2009, 07:53 PM
ScionFred's Avatar
huh... that's interesting. Typically the E housing has a larger backplate than the B and uses 2 half-circle clamps. I know that the 3x2 bolt clamps from a T04B won't work on a E. I didn't know that there were larger 3x2 bolt clamps for the E housing but now I do. Thanks.
Old 11-11-2009, 08:09 PM
you are talking about these right when you say clamps?
Old 11-11-2009, 08:37 PM
ScionFred's Avatar
Yes and your backplate appears to be larger than my T04B and the same as my T04E. You could pull your covers off and measure your wheels to see exactly what you have (stage and trim) but it's probably a lot easier to cross reference the part # or serial # with Turbonetics. If you even care that much about it.
http://74.208.101.201/forum/tech-sup....html#post5821
Old 11-11-2009, 10:48 PM
Well i kinda wanna know my wheel stage. Now i know the stage II wheel is good for like 400-425 whp according to turbonetics spec. So im guessing for a quicker spool up and more usable powerband i would want that right. Instead of a stage III wheel thats for i think 450-500hp?
Hey thanks for all the links and incite Fred! I just learned some things.
Old 11-11-2009, 10:50 PM
hey i actually posted there. Same s/n. Im the first post on the second page and so far the only post. Hopefully they can tell me without opening up the backplate.
Old 11-11-2009, 11:58 PM
ScionFred's Avatar
I did some googling and I think what you have is a .63 a/r turbine with stage 3 wheel and a .60 a/r T04E comp with 50 trim wheel. It's the same as my Precision 5031E. Check the turbine housing again for a stamp that reads "stg III".
I know a little about turbo sizing but not enough to offer any advice on the subject. I suggest reading up on it at Garrett or Turbonetics websites or asking some of the more knowledgeable folks around here.
Check this out for a quick sizing guide:
http://www.turboneticsinc.com/sites/...0Matrix%20.pdf
Old 11-12-2009, 12:08 AM
B_Real45's Avatar
I T04E 50 trim is capable of 450hp. Of course it all depends on the supporting mods you have and the tuning.
450hp will roughly be 47lb/min which this turbo is capable of pushing - however you're at the very end of the efficiency map by then.
B_Real45 is offline
Old 11-12-2009, 12:17 AM
really? Hmm... the guy i bought it from said it was a .50a/r comp and exhaust .63a/r. But maybe he said 50 cause it being a 50 trim. I will look more into it. I dont see anything on the comp housing other than 30491 E50. there is a 12 stamped on one of the comp wheel blades. Im very interested to finally figure out what i got. I mean i know its a real turbonetics turbo. I know it will give me plenty of power. I just want it to spool decently quick and give me some good power numbers.
Old 11-12-2009, 12:19 AM
Interesting Breal! Thanks for that post. Ima really only looking to go to 10psi max and hoepfully make around 300whp there. Ima start out around 5-6psi just to get used to driving a turbocharged car.
Quick Reply: difference in 2 psi
