Do I have to put stock injectors in if I have a stock ECU?
No, your car will idle with a violent shake! Well at least it does with 550s. Trust me I know...
If you have a flashed ECU then yes you can run the 440cc injectors without the blower...but you have to keep the SC air-box that the MAF is mounted to.
If you replace the air-box to the stock model then you need to change out the ECU and change out the injectors as well.
There is a post from Garage witth info that will allow you to re-program an ECU off a doner vehicle. You need a new non-flashed ecu to go back to stock.
JM Auto Racing
12-19-2014 06:36 PM
darkshadowofxdeath
12-03-2014 06:59 PM
