Dyno Results...
Old 12-13-2010, 06:11 PM
  #41
thendawg's Avatar
Dont worry, more boost will be coming soon Looks like my ultimate will be here by the weekend. If I can solder and install with one hand, than I should be tuning on it over the weekend to get a running street tune, than hopefully find someone to tweak it on the dyno in the next few weeks
thendawg is offline
Old 12-13-2010, 07:35 PM
  #42
crush02342002's Avatar
good luck
crush02342002 is offline
Old 12-13-2010, 07:40 PM
  #43
thendawg's Avatar
Yea ill need it... I have a cast on my left hand/arm lol - luckilly Im right handed Also with the amount of timing Im pulling, do you think Ill get quite a bit more out of it by advancing timing? Esp considering its 9:1 cr? I dont plan to tweak ign timing until I can get it on a dyno to reliably monitor knock.
thendawg is offline
Old 12-13-2010, 07:53 PM
  #44
advancing timeing early on in boost will help out quit a bit with how power comes on and spool up.
I cant say just how much of a change you will see but i can promise you will see a gain unless you start knocking.
Old 12-13-2010, 08:15 PM
  #45
m6ar2cel6oTC's Avatar
howwill he know hes knocking on the fic and not on a dyno? how much added timing on spooling you think?
m6ar2cel6oTC is offline
Old 12-13-2010, 09:11 PM
  #46
what are you talking about? seriously im kinda lost. so far you cant monitor knock with the fic without having some odd ball problem. I forget exactly what the deal was but someone tried it. On the dyno you can monitor your timeing via scan gauge and if you suddenly see timeing dip down you know you hit knock. also if you have a high end scan tool you can datalog. I think code scout has this ability. you could do this on the street too but its kinda hard to do all by yourself.
At one time i was hopeing to figure out a way to tap into the knock sensor and run an led on the dash. you get knock and the led lights up. Just got to figure out how it would all work.
Old 12-13-2010, 09:50 PM
  #47
thendawg's Avatar
Haha thats exactly how i monitor for knock, i use scanxl through an elmscan and record street tuning pulls Ive yet to ever see it really dip like it was sensing knock, in fact pull over pull it seemed to advance timing. Im sure I can push it further, however Ive heard with E85 its pretty hard to cause knock.
thendawg is offline
Old 12-14-2010, 12:23 AM
  #48
hey thendawg mind showing your timing map..
crush i see what your saying but didnt know what thendawg was using to monitor knock. and they used or they still do sell knock lights. some look like shift lights.i think all you do is hook it up to your knock sensor but i can be wrong.
Old 12-14-2010, 01:57 AM
  #49
thendawg's Avatar
Yea - Ill take a screencap when I get home - remember this is on the FIC so its simply showing timing being pulled, not actual ignition timing.
thendawg is offline
Old 12-14-2010, 02:42 AM
  #50
yea i know just curious tosee it.
Old 12-14-2010, 02:45 AM
  #51
yeah i seen those...almost got one too but i couldnt get any reviews on it...I hate being the guinea pig...lol
Old 12-14-2010, 02:51 AM
  #52
Old 12-14-2010, 02:59 AM
  #53
thendawg's Avatar
Heres my timing map - Im still looking for the datalog file form the dyno session - I dunno why it didnt save it in the normal location :/
thendawg is offline
Old 12-14-2010, 03:57 AM
  #54
creamyxb2's Avatar
ieieieiieieiieieieieieieeii. wow. those are good numbers for tuning yourself.
creamyxb2 is offline
Old 12-14-2010, 04:22 AM
  #55
the psi is from bottom to top? and rpm from left to right? i cant understand it much cause of that.
Old 12-14-2010, 04:24 AM
  #56
mmmpshh's Avatar
nice!
mmmpshh is offline
Old 12-14-2010, 04:42 AM
  #57
found a little info on the turbo xs knocklight (pic i posted above) as well as another knock light review.
http://bbs.scoobynet.com/512314-knock-link-3.html
thendawg your ign map doesnt look bad imho, could use a bit more refineing. i see some jumps that could use a little smoothing but i wouldnt change a thing till you get up in the dyno.
honestly im impressed thendawg.
good job and good luck.
Old 12-14-2010, 04:44 AM
  #58
boost pressure is in absolute not gauge pressure (that throws most people off), but yeah you got the gist (boost up and down, rpm left to right.
Old 12-14-2010, 05:03 AM
  #59
thendawg's Avatar
Yea boost is bottom to top, than rpm is left to right. Boost is in absolute pressure so 14.7 is "0" on gauge pressure - for instance 10 psi boost would be 24.7 psia on this map
thendawg is offline
Old 12-14-2010, 06:01 AM
  #60
btw i just noticed on the map around where you would redline you havnt taken any timeing out.
Quick Reply: Dyno Results...
