E-manage ultimate help
So, i unplug stock ecu, plug in the emanage, plug harness to emanage and all the other wires on the other side of the harness to the stack ecu? If i do it wrong will it mess up the whole car? Or No? A little more detailed instructions will be cool please cause im not good with wiring. Thank you for the help tho.
sorry i wasnt very specific :p
OK if you bought the harness, you will plug the stock wires that go into the ecu, into the "female" type connectors that are on the side of the harness with TWO sets of connectors (8 total) the MALE connectors on that side will plug back into the stock ecu, they will only go one way... the connector that is off on its own... that one plugs into the emanage ultimate.. bang, done
if you didnt buy the harness... BUY IT
U need a Plug & Play, unless u want to cut and solder wires on to the stock ECU wires. U sure u want to take that risk? I say buy a Plug &Play Harness. What year is your car?
Originally Posted by krazylowgsx
last time i checked with Kenny, there wasn't a plug and play harness available for the ultimate! if you find one, let me know, b/c i have one sitting here that wil be installed too.
05-06
http://www.dezod.com/pd_dezod_motors..._plugnplay.cfm
07+
http://www.dezod.com/pd_dezod_motors...e_ultimate.cfm
Majic is in the air. P.S.-in stock too!
05-06
07+
carid
08-31-2015 11:17 AM
Subaru86
07-31-2015 04:00 AM
TheTripleC
01-04-2015 06:46 PM
