E85
the concern is more on some type of rubber/teflon fuel lines.. it causes some of those to get hard and brittle over time and eventually break due to pressure.. i say those with aluminum rails and braided lines should be good..
Yeah i think for some people it could be a little bit of a hassle to get to the E85 station...what if you are driving somewhere far and not sure if E85 stations are along your way..then what.
I'm still debating if i should get E85 or not, i mean its octane on par with race gas but it's not too common in NYC area, i think for now i'm going to stick to 93 octane.
^^ im waiting for hydra 2.7, flex fuel feature.. but i did drove to san antonio once like 220ish miles with 7 gallons extra e85. Yeah its a pain to find some stations, when i got to my e85 station in san antonio it was a retail e85 station so ended up with regular gas and suffered a crappy tune for a bit
^^ did try that at one point, its still not smooth.. fuel trims can get close though but the cranking/start up just sucks, tip in afr arent good either.. i did it only for just a bit coz i just loaded a gasoline map and save some headache. i might try it later sometime maybe i'll get it figured out
Back when I played around with it, I would have both e85 maps and 91 octane maps plus two intermediate maps, one going from ethanol and going to it. I would only bring these on long trips where I wasn't certain on fillup stations, but it did come in handy. Flex fuel option would be sweet.
You don't need as cold as you would need on pump gas. I think one step colder should be fine.
still working on the 2.7,no release date yet but it comes on different stages depends on needs.. Im still using the 2 step colder, but ran leaner afr 12.0.. I widened my plug gaps to 0.034"
hmmm interesing point about the flex fuel option that would be really nice to have but i dont see that happening for me until i can get a hold on a standalone but still interested to see how this could work out this could really open up options i think for some ppl who r not as lucky to have an e85 station near them
i rock the eth running 25-29 psia
drive hard
tune like i hate my car
run 13.5 afrs up till 6 psi generate heat like a mo fo
pull no timing till 8 psi
then tune about 12.8-13 till 12 pssi
then 12.5 till red line
pull a half degree per psi past 8
it rocks im a alcoholic
get about 15-25 mpg average about 29 on highway at 70-75
yes i did
yes i did
yes i did
drive hard
yes i did
yes i did
yes i did
