ECU Question
There are a couple of different ones being used. To name a couple are the E-manage, unichip, safc-II and AEM. Emanage and unichip are the more common ones. All seem to work fairly well with the tCs ecu. Cheapest being the emanage but i've heard stories of the tC's ecu overiding the map. I'm sure some others who are actually running any of these piggy backs can give you a little more info.
All of the piggy-back computers are the same in that they are only useable when your stock ECU goes into open loop at WOT. Your stock ECU will overwrite any other changes made.
The AEM is currently an in-development standalone that will run you ~2,000 but you'll be able to change just about anything.
Dezod is working on their sup3r s3kret computer that will do virtually the same but still be a piggy-back (If I read the other threads right)
