ElevationTC.. Mtuned... SUPERCHARGED STYLE O.o
Old 05-31-2011, 12:14 AM
ElevationTC's Avatar
Default ElevationTC.. Mtuned... SUPERCHARGED STYLE O.o
So Some of you may of herd of me... Some may not have..
I have had almost 5 - 6 Different turbo kits
Ive been any where from 9-22 PSI On stock block.
E85
C16
30PSI on A turbonetics kit.
Ive made 395 whp on mustang dyno stock motor..
But in the end, I ended up all stock again..
A friend of mine whom used to be supercharged had his old trd charger laying around.. And i thought to myself.. WHY NOT!
Tommorow starts the project folks. Quick run down of whats going on here.
TRD Supercharged, Gompka Shaft Ceramic bearings.
14 PSI pulley
Emanage ULT
700cc injectors
walbro pump
Custom FMIC
Raising redline to 7200
Stock motor
E85
Return fuel system
3" Header-back
Custom long tube 4-1 headers.
Going for 12 second supercharged tc =D
Ill update this as soon as i can...
Thanks all!
ElevationTC is offline
Old 05-31-2011, 12:21 AM
Music City Scions
rhythmnsmoke's Avatar
checking in...
rhythmnsmoke is offline
Old 05-31-2011, 12:23 AM
brett561tc's Avatar
brett561tc is offline
Old 05-31-2011, 12:32 AM
Serious brett, Shoot me a txt.
Old 05-31-2011, 12:37 AM
brett561tc's Avatar
14 psi pulley at 7200 rpm will be more like 18psi.
Old 05-31-2011, 12:43 AM
=D
Old 05-31-2011, 12:56 AM
brett561tc's Avatar
this should be interesting.
Old 05-31-2011, 01:15 AM
Skeeeett's Avatar
subscribed, gl w build 20? llol
Skeeeett is offline
Old 05-31-2011, 01:23 AM
youngflyer's Avatar
cant wait to see results
youngflyer is offline
Old 05-31-2011, 01:33 AM
trd07tc's Avatar
probably going to run out of fuel at high rpms
trd07tc is offline
Old 05-31-2011, 01:41 AM
speedy000's Avatar
why would he run out of fuel? 700cc and fuel pump should be good.
im in for this build!
mike is an O.g. i haz trust
speedy000 is offline
Old 05-31-2011, 02:08 AM
05rs1's Avatar
very interested in this....good luck!
05rs1 is offline
Old 05-31-2011, 02:11 AM
johnnyb305mia's Avatar
Look at the guy haha mike always inventing new ish...
Sent From My Evo
johnnyb305mia is offline
Old 05-31-2011, 02:15 AM
emrules2001's Avatar
Exhaust? I'm guessing 240whp
emrules2001 is offline
Old 05-31-2011, 02:26 AM
3"
Lolz. If you think running e85 and 16-18 psi of boost will yield 240whp
I should note that there will be fuel return system.
Old 05-31-2011, 03:08 AM
pioneer1976's Avatar
cant wait to see what you can do with this
pioneer1976 is offline
Old 05-31-2011, 03:10 AM
mmmpshh's Avatar
hmmmm.....
mmmpshh is offline
Old 05-31-2011, 03:11 AM
thendawg's Avatar
Cant wait to see this! Increased rev on supercharger should give a good 16-18 psi on that pulley With E85 and everything else, this has the makings of awesomeness haha. Oh with 700's and a return you should be fine. I got to high 300's on 650's with a really high base pressure (75 psi).
thendawg is offline
Old 05-31-2011, 03:22 AM
Thats what i'm hoping for. I would like to run the Bosch 044 inline pump for all pressure needs =D
Those new big intake's supply Alot of fuel, but as fuel pressure increase's flow drops off alot!
running the 14 psi pulley should yield decent boost at lower RPM's I really wish that someone would make a larger pulley for the crankshaft, but i belive the timing cover timing post would interfear.
I will not be running the trd ecu, so the timing curve will be much more aggressive then any have seen in the past. Vortech claim's the trd blower it self would be capiable of producing around 500 Flywheel HP. And IMO a good 300-350 WHP will put me in the 12's with traction.
Old 05-31-2011, 03:51 AM
x_Batman_x's Avatar
watching
x_Batman_x is offline
Quick Reply: ElevationTC.. Mtuned... SUPERCHARGED STYLE O.o
