Emanage question?
Emanage question?
I have the lil blue greddy emanage and the zpi pnp harness when i plug it up and start the car it idles fine and everything but when i try to drive or rev it, the turbo wont spool up. Is this because there is no mapping yet and no base map and i have to wait to get it tuned? or is it because of something else?
Originally Posted by sensay
whaa?? that doesnt sound right. The only way your turbo wouldnt spool up is if its manifold wasnt connected. Be more specific
Well, the emanage blue box should allow the ECU to run stock with all the Greddy defaults set.
I believe there is 1 switch that needs to be changed from the factory setting inside the emanage. Check them all, but I believe it's JP2 that will change. If you look in the Greddy manual, you will find these setting and what they are.
Jumper Settings:
JP1 – 1-2
JP2 – 2-3
JP3 – 1-2
JP4 – 1-Open
JP5 – 1-Open
JP6 – 1-Open
JP7 – 1-2
Jumper Settings:
JP1 – 1-2
JP2 – 2-3
JP3 – 1-2
JP4 – 1-Open
JP5 – 1-Open
JP6 – 1-Open
JP7 – 1-2
check your wiring is it that the turbo will not spool or the engine will not rev high enough to make the turbo spool. what harnesses are you using on the emnanage? ignition? injection? do you have the emange software? if so clcik the green box at the top and make sure that you are getting a TPS, RPM, MAF readings. If one of these are not working it may be a wiring issue. Give me a call or IM on monday if you can not figure it out.
