energy suspension motor mount inserts
Old 07-13-2008 | 10:08 PM
  #41
Mr_Meaty's Avatar
Originally Posted by Ace83
where did you get speed source? I guess this energy motormount is more complete?
http://www.speed-source.net/
I don't even have my rear in...aen got his rear put in when they did his clutch...he said he barely notices any difference then without it.
This would make me lean towards the TurboToyotas Billit front motor mount which looks SICK!
Old 07-13-2008 | 10:45 PM
  #42
Ace83's Avatar
Ronin Scion
^^ i've been waiting for that but I dont know if todd wants finish that, so i just decided to go buy mounts already
Old 07-16-2008 | 03:31 PM
  #43
Ace83's Avatar
Ronin Scion
so energy suspension offers full replacement and inserts? where can i get full replacement? most i see are just insert..
Old 07-16-2008 | 03:40 PM
  #44
TCpete's Avatar
the ES mounts are the same exact thing as the speed source mounts only that speed source charges you EXTRA because they are giving you a fabricated metal mount to replace the front engine mount completely.. the ES eliminates the extra fee and hand made mount cost... so u can still use your same mounts.. but your replacing the inside with solid bushings.. instead of the stock bushings.. got it ACE?
Old 07-16-2008 | 03:43 PM
  #45
Ace83's Avatar
Ronin Scion
^^ gotcha, some said they got full replacements instead of inserts from ES so that confused me, but doesnt matter, thanks for clearing it up
Old 07-16-2008 | 04:56 PM
  #46
TCpete's Avatar
no worries.. the inserts were OLD releases.. the new ones dezod carries are FULL>.. if u want pics LMK and when i get them on friday ill show you.
Old 07-16-2008 | 05:17 PM
  #47
Ace83's Avatar
Ronin Scion
^^ yea take some pics if you can, there's pics i see around like on ptuning's thread but the more the better..
Old 07-16-2008 | 05:43 PM
  #48
paul_dezod's Avatar
Scionetics
KAD
FYI, here is the PDF install manual from Enenrgy for the mounts:
http://www.dezod.com/files/8.1104.pdf
Old 07-16-2008 | 05:48 PM
  #49
TCpete's Avatar
will do.. and i got mines from PUAL @ dezod!.. ill try to post pics installed also asap when they come in for you ace
Old 07-16-2008 | 08:50 PM
  #50
ignitionr34's Avatar
i definetely noticed a difference when i had my rear speed source mount put in.... there aer ALOT more vibrations and everything feels a lot stiffer when shifting
Old 07-16-2008 | 09:06 PM
  #51
TCpete's Avatar
how was it when u put the front one in.. or did u just put both in at the same time..
Old 07-17-2008 | 06:30 AM
  #52
no i actually put the front in myself... then about like 3 months later when i got my clutch done i had my mechanic put the rear one on. the fron still felt good cuz i did eliminate a good amount of wheel hop, but have nto launched it w/ the rear one on yet... but i know it will make a huge tremendous cuz i can already tell by driving and flooring through each gear
Old 07-17-2008 | 02:21 PM
  #53
Mr_Meaty's Avatar
what about the third one, under the battery...did you do that when you did the front or the rear?
Old 07-18-2008 | 03:42 PM
  #54
TCpete's Avatar
pic as promised.
as you can see they are 100% solid polyurethane and replace all the stock oem rubber crap...
Old 07-18-2008 | 04:27 PM
  #55
Ace83's Avatar
Ronin Scion
^^ nice, i'll be getting mine soon
Old 07-23-2013 | 04:13 PM
  #56
Mr_Meaty's Avatar
Old thread...I know...But whatever.
I hadn't been pushing my car for awhile so I sold/traded my speed source mounts for stock ones. What's funny is the stock bracket has that part sticking up from the top. I had the SS in when I installed the turbo kit, and when I switched back I noticed that the kit does not clear the top part! I had to use my friends huge power saw to cut through top part off...not sure how that effects performance of the stock mount.
I got rid of it because of the excessive vibration at idle. But now I'm noticing alot of engine rock, so I'm thinking of getting new mounts again. Probably the pTuning full replacement. No pressing and comes in 3 different stiffneses, so I can get a mild one.
XirtaXa
23
07-14-2021 05:33 PM
MinusPrevious
15
12-12-2020 06:47 PM
Sumtallguy
03-24-2015 04:55 AM
jenkay
12-17-2014 03:25 PM
trickedxb
9
01-16-2004 07:34 PM
Quick Reply: energy suspension motor mount inserts
