engine stalling....already searched still need help
you can open cent your valve cover just as long as the one in the back is hooked up i have mine vented and are you tuned??? and i bet it stalls when you come out of boost and push in the clutch you can solve this by letting of the gas for a second or two then pushing in the clutch
It'll still stall after I let it coast for about 5 seconds then clutch it. Even if I down shift to a stop after boost it will. As far as I know the one on the back we never touched because there wasn't a need to. And yes I'm tuned....but I am still runnin the stock injectors, my 550s are comin this week.
the main stalling problem is fixed. the problem now is that i dont have closed loop control and when it goes from open to closed loop it gives a super rich reading on throttle let off. im looking into open loop map tuning or a black box from dezod right now.
soflo the synapse with the anti-stall kit is NOT recirculated. the anti-stall kit allows you to still vent to the atmosphere and not have the stalling issues. and it sounds Great! also NO surge what so ever
*EDIT* Also, if you need any help I'm only 2hrs away in Auburn. I know the tC backwards and forwards.
