engine wont turn over!!!!
Old 03-29-2010, 07:12 PM
craftedinsane's Avatar
Default engine wont turn over!!!!
i just put my engine back in my tc last night after boring, forged pistons, rods, valve job, balance shaft delete, and all i get is a putt putt putt from the motor. the battery is delivering juice (relocated to the trunk with 0awg gauge) this is a custom forced induction motor, both previous and now, its running off a emanage blue and its working right. any suggestions?
craftedinsane is offline
Old 03-29-2010, 07:16 PM
m6ar2cel6oTC's Avatar
Default Re: engine wont turn over!!!!
Get rid of your emanage blue and search there have been a lot of threads with your situation. Look through it you might find something.
m6ar2cel6oTC is offline
Old 03-29-2010, 08:07 PM
DezodDon's Avatar
Won't start or won't crank? What did you do for grounds?
DezodDon is offline
Old 03-29-2010, 08:43 PM
catracho16's Avatar
my friend has a similar problem he took the motor out and relocated battery to rear, once all put together the light would flicker and motor would just putt putt putt but not turn over.
after like months and a millions other ways to fix it.....it was a ground issure with the battery..so has to d something with the grounding of the battery
catracho16 is offline
Old 03-29-2010, 09:42 PM
trd07tc's Avatar
step 1 . grounds
trd07tc is offline
Old 03-29-2010, 09:49 PM
cburglb34's Avatar
make sure the battery is grounded, and the engine is grounded to the chassis....i always see customers forget to ground the engine....
cburglb34 is offline
Old 03-29-2010, 09:55 PM
ElevationTC's Avatar
Customers were do u work?
SECRETS!!!!!!!!!!!!!!!!!!!!!
ElevationTC is offline
Old 03-29-2010, 10:07 PM
brett561tc's Avatar
http://www.youtube.com/watch?v=G-tCIRJH9p0
brett561tc is offline
Old 03-29-2010, 10:20 PM
crush02342002's Avatar
^^lol..priceless
crush02342002 is offline
Old 03-29-2010, 10:31 PM
cburglb34's Avatar
lo out of my buddies garage i thought i told u i used to work on supras and lexus.... oh well those days are long gone im jobless
Old 03-29-2010, 10:33 PM
WillyB's Avatar
^^lol
WillyB is offline
Old 03-29-2010, 11:09 PM
The battery is grounded twice with a 0awg and a 4 gauge. The engine is grounded twice with the same. Locations are both sides of the valve cover. This is driving me crazy
Old 03-29-2010, 11:12 PM
And it won't crank. The starter is turning the flywheel but won't crank. Spark are good and grounds are good. Also getting fuel to the injectors.
Old 03-29-2010, 11:32 PM
cburglb34's Avatar
u didnt ground the trans... thats where u should ground... anyways alot of ppl with thte 2az after building wont crank over becaus eof the cam sensor
Old 03-30-2010, 12:07 AM
Or timig chain. Bro it can be so much. You should look into the service manual! Just look through all the pages that show putting back the motor togeter and it will show you alot.
Old 03-30-2010, 12:42 AM
yamaha16bw's Avatar
If its turning, getting spark and fuel like you say then its the timing chain....and that seems to be the case 99% of the time on SL with engines that wont fire.
yamaha16bw is offline
Old 03-30-2010, 01:54 AM
deathbyc4's Avatar
check all the spark plugs, mine were covered in oil when i started mine up lol
deathbyc4 is offline
Old 03-30-2010, 01:55 AM
just found out my throttle body is blowing air instead of sucking in air.. def the timing chain... thanks guys. is there a quick thread that will lead me to a diy timing chain lol
Yup that was my problem.
Old 03-30-2010, 04:23 AM
gingles's Avatar
what....what
oh yea...that was my problem bahaha....just check your timing on the cams first so you dont have to pull off the timing chain cover.
if you want to know what the cams should be set at....search for a thread by yamaha....best pictures of it.
gingles is offline
Quick Reply: engine wont turn over!!!!
