Exhaust Size for 300hp Range
Hey guys im looking to make an exhaust next week what sizes is everyone running to make around 300hp. Right now i have a dezod s1 (turbonetics t3/t4 .63 trim) Kit.
I dont know whether to go 2.5 or 3...right now i have a skunk 2 s pipe back which is 60mm (about 2.36in) and i beleive that is holding me back...
3" will be the most efficient, and what I would recommend. Can you make 300whp on 2.5"? yeah definitely - Ive made 400whp on 2.5", but 3" will be MUCH more efficient when you start getting into that range.
i have a small t3/t4 .50 trim with a 2.5 inch crushbent exhaust, i was tuned at ptuning for 10-11 psi car made 280hp there, i have since put in a 13psi spring and then got dynoed at a local shop the attached dyno is the results also people cannot say that the dyno doesnt read like ptunings because i raised the boost 2 psi and the en result was 20 hp which goes with the general rule of thumbs for every 1 psi of boost you raise you increase 10hp. now had i had a 3inch exhaust these numbers would have came at maybe 10 psi
